Thread: Any Techies Help
    Regular Member Dave F's Avatar
    STOKE-ON-TRENT
    Default Any Techies Help
    after reading the recent thread on tuning box downsides, there seemed to me to be a general opinion that tuning boxes put extra strain on the common rail components.
    I got to thinking could a switch be fitted into the circuit so if you didn't need the box (cuz you were taking your gran to collect her pension say) then you could activate the switch, taking the box out of the circuit and hence reducing the extra strain on the common rail for as long as the box was deactivated. I'm sure that would help for most people, and increase the life of the injectors.
    so techies is it possible ?
    [Ex]Admin Duncan's Avatar
    I've recently had a conversation with Mike at Diesel Tuner about this very subject. He says it's a piece of p155. I've left him with it, and he's getting back to me.
    South Central England
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I asked him about it nearly a year ago and he said it could be done but he would want to charge me a bundle!
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Still working on a button for mine, the components I'm using seem to draw too much current or create a voltage drop across them.
    In essence all I need to do is flip from one feed to the other and keep them both isolated but it needs to flip over fast if the engine is running. A switch that could be used to turn it on and off while the car is off is no problem.
    Administrator plasma's Avatar
    On the Forum
    360 Post(s)
    Engine : 150
    Mileage : 74000
    what you need is a switch that doesnt break or make till u release it, not during the travel time from one state to another. then its only the time it takes for the contacts to change over. does this make sense to you?
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Yes, I was trying to use transistors to make a logic gate but as I said in another thread, the transistors seemed to be drawing/limiting voltage or current and ******ing it up.
    I've been thinking some more and this is what I've come up with now...
