Results 1 to 10 of 15
Thread: 3.0 CDTi EGR Valve
    Belfast
    Default 3.0 CDTi EGR Valve
    Has anyone removed/changed the EGR valve on a 3.0 V6 CDTi (Y30DT) engine (as a DIY)?
    I am hoping to clean mine and have tried searching through the HOW 2's to no avail.
    It seems that there is quite a lot in the way, over the top of the EGR unit and was hoping someone can give me a few pointers!!
    PS. Replacement EGR Valve quoted @ £298 +VAT OUCH!!!! - So, me thinks I shall try to clean the existing one first!!
    What symptoms are you suffering to make you consider cleaning / changing the EGR valve?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Cleaning won't work on the 3.0. It's either working or not. It might be sticking and still work but once it goes (limp mode) your only option is to replace it.
    Quote Originally Posted by Celes View Post
    That's what I had been told previously as well
    However if the car is producing black exhaust smoke the pipe to the turbo may be faulty and need replacing
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Which pipe? The EGR cooler?
    There is a pressure relief pipe from the EGR to the turbo
    This often cracks, air gets in, and results in black exhaust smoke
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    not heard of the pipe failure but their are no other 3.0 in the area to break. get more then enough 1.9's to repair.
    as above mate don't touch what aint broke
    Belfast
    why wont cleaning have any advantage?
    As above, what symptoms are you suffering that makes you want to consider cleaning or replacing the EGR valve?
    The EGR valve on the Y30DT is a hardy piece of equipment, compared to its VX equivalent!
    Belfast
    It all started when towing our touring caravan on the motorway probably in 5th at around 55mph, i initially thought the turbo had packed in as it just felt like I had no power or acceleration. Stopped the car, and switched ignition off and on and the problem disappeared for about 10 miles until it reappeard only with the spanner light on this time.
    The car had been a little "lumpy" previously and I had thought i had got a fill of dirty deisel, so tried the fuel additive/cleaner and thought the problem had cleared as the spanner light disappeared a few days later and the car seemed to be running ok.
    Towed the caravan a week or so later again and the same thing happened again, loss of power and spanner light on, which again dissappeared after a few days after towing.
    The car does seem a little but sluggish and jerky at low revs now.
    Diagnostics at local indy showed fault with the EGR hence the idea to give it a bit of a clean.
    Its really doing my head in!!!!
  1. Sri 120 cdti 8 or 16 valve
    By hamish123 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 22:07
  2. EGR Valve for CDTI 150
    Last Post: 19th August 2009, 15:13
  3. EGR Valve on 1.9 CDTi 150
    By bappy in forum Engine & Drivetrain
    Last Post: 12th August 2009, 20:48
  4. EGR valve 1.9 CDTI
    By parsco in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2009, 23:09
vectra c 3.0 cdti egr valve off
vectra 3.0 cdti egr valve removal
https:www.vectra-c.comforumshowthread.php115095-3-0-CDTi-EGR-Valve
3.0 d vauxhall changing egr
vectra c 3.0 v6 cdti egr valve
is i easy to take off egr valve vectra v6 cdti
egr signum 3.0
where is egr valve on vectra 3.0
vauxhall signum 3 litre diesel egr unit
opel signum v6 egr off
signum 3.0 cdti egr valve location
vauxhall vectra 3.0 cdti egr valve
vectra 3l v6 cdti egr location
z30dt egr valve part number
signum 3.0 cdti 2003 egr location
can you disconnect the egr valve on vectra 3.0 diesel
3.0 v6 cdti egr symptoms
3.0 cdti egr
egr valve opel vectra cdti 3.0 v6
Vauxhall signum 30cdti egr valve
vectra v6 cdti egr location
v6 cdti egr sticking
vectra cdti v6 egr valve
vectra c 3.0 cdti motor egr
vectra cdti v6 no power
