Thread: Auto Gearbox Oil Change -Special Oil?
    Vale of Glamorgan
    Default Auto Gearbox Oil Change -Special Oil?
    Morning all,
    My Auto Veccy C has been jerking a bit during some gear changes recently so I thought I had best get the gearbox oil changed etc.
    I've had a price from a local garage of £45 + VAT to change it as long as it isn't special oil it needs. Does anyone know if it is standard gearbox oil in these things or something special? Also does £45 sound about right?
    Thanks,
    Jim
    The AF 40 box on the cdti uses Vauxhall automatic transmission fluid (93 165 147) or its equivilant from another maker.
    Vale of Glamorgan
    I'm taking the Super Vec up to Birmingham this weekend and whilst its there my missus uncle is going to fit a replacement fog light etc. Ive asked him to change the ATF as well but he said they are filled for life and he's only ever heard of 2 being changed. He works at a main dealer and usually knows his stuff. Is the 40k recommended change fact or fiction? He also said it would be atleast £150 as theres no drain hole and you need to take the sump off etc. Any opinions?
    Oct 2009
    Bilbao&Madrid
    Vehicle : Opel Signum
    Trim : Cosmo
    Engine : 3.0 CDTI Z30DT
    Check this discussion:
    http://www.saabcentral.com/forums/sh...d.php?t=171213
    as the box seems to be the same as ours.
    Oil must must conform to AW-1 specifications.
    I'm not sure about how difficult/different is to change the ATF compared to other models as this is my first automatic and I never paid much attention to this in my previous cars' workshop manuals.
    I do remember that in a CitroŽn Xantia, though, not all the transmission fluid was changed in an "ATF change" (as it done in a manual box), but part of it (less than a half): it seems the same as the procedure described in the Saab forum.
    So if you add the price of just 3 litres + estimated labour costs... 150 pounds sounds like a 2 hours job, 45 pounds like a job done in 15 min.
    Regarding the periodicity of the changes, for MY2006 onwards, Opel (in Spain) says you should change your AT oil every 48000 miles/80000 km or every 6 years (engines Z28NEL, Z28NET, Z30DT, Z19DT, Z19DTH). Every 4 years or 60000 km for other engines.
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    ^That seems about the same as vauxhall uk.
    For auto transmission: -
    "Haynes" recommend changing it every 4 years or 40k miles. I'd imagine this is the same or similar to Vauxhall uk's service schedule.
    I'd have to agree with that Saab poster - "let the dealer do this!". Not worth saving a few quid by going elsewhere, for peace of mind make sure this is done right.
    For manual transmission, it's not part of the service schedule & you never need to change it. Best left alone unless there's a problem.
  1. Auto Gearbox Fluid Change
    By Homer in forum Engine & Drivetrain
    Last Post: 15th November 2012, 10:50
  2. Auto Gearbox Oil Change
    By rocket999 in forum Engine & Drivetrain
    Last Post: 22nd June 2011, 19:46
  3. change gearbox oil on auto signum
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2010, 15:41
  4. 3.2 auto gearbox oil change
    By gtr1000 in forum Engine & Drivetrain
    Last Post: 2nd March 2008, 12:48
  5. Auto gearbox oil change
    By Elevonic in forum Engine & Drivetrain
    Last Post: 28th August 2007, 12:45
vectra c cdti auto gearbox oil
vauxhall vectra automatic gearbox oil change
how to change gearbox oil in insignia automatic 2011 model
insignia auto box oil change frequency
how much gear oil goes in saarb 93 cdti
vauxhall zafira automatic gearbox oil change
insignia transmission fluid location
how to fill zafira auto gearbox oil
how long to change zafira c gearbox oil
af 40 automatic transmission
how much gearbox oil for vauxhall cectra cdti auto
insignia automatic gearbox oil change
change automatic gearbox oil corsa c price
changing oil on gearbox on insignia
what oil use opel signum automatic gearbox
vauxhall signum automatic gearbox oil change z28net
opel insignia automatic transmission oil km change
vectra c 3.0 auto gearbox oil change
af 40 automatic gearbox oil change frequency
how much atf in vectra c
2011 vauxhall insignia auto gearbox refill
vauxhall 93-165-147
the cost for vauxhall vectra gear box oil change uk
opel vectra c gear oil
