Hello! We have a 2004 vectra 2,0 dti. In the display who shows outsidetemperatur its only now and "F" there. Someone had the same problem?
Mine does this when the Temp sensor in the bumper grill is unplugged. HTH
I have checked this. Also tryed with another. Its still the same F
Have you checked where the bumper wires plug into the body wires? This may seam really odd, but when my ABS plug was dirty is also made the F pop up along with other dash faults, it could be that?
Ok. I would check ABS wires and where its fasten to the body wire. Thanks for tip
Just unplug it and spray with contact cleaner.
Unplug battery for about 5-10mins and problem should be sorted once you hook the battery up again as this worked for me when I got the F in the display. Hth.
