Thread: Limp mode in 3rd 4th and 5th at just under 3000 revs
    Apr 2009
    stockton-on-tees
    Default Limp mode in 3rd 4th and 5th at just under 3000 revs
    My 2.0 dti keeps goin into limp mode I've checked for splits in hoses and vac pipes and I've also cleaned my egr just seem strange it only does it in 3rd 4th and 5th
    EVERYWHERE
    Quote Originally Posted by barrymanalow87 View Post
    Try cleaning boost sensor.
    Also, you will get more feedback if you post it in the 'Engine & Drivetrain' forum.
    Apr 2009
    stockton-on-tees
    Tonite I've cleaned egr valve boost sensor and barometric pressure sensor also I've checked for split hoses and it is still goin into limp mode
    Regular Member AKeeNShoT's Avatar
    South Shields, T&W
    i have read on here, or have been told by a very reliable source that an often over looked possibility is the crank sensor, and actually believe it or not, the off side abs sensor, someone on here will confirm though, any problems with the abs cutting in when braking to a stop and turning at the same time?
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    this is happening to mine and its driving me mad.
  1. 30000 revs spanner light .limp mode .vectra 2.0 dti 2004
    By davemander in forum Engine & Drivetrain
    Last Post: 19th February 2013, 00:07
  2. Low Power, Wont Go Above 3000 Revs
    By jammin31 in forum Engine & Drivetrain
    Last Post: 30th June 2011, 10:20
  3. 2.0DTI Engine Fault - Limp Home Mode Over 3000 RPM
    By coxstevuk1973 in forum Engine & Drivetrain
    Last Post: 4th March 2011, 17:03
  4. vibration after 3000 revs
    By lordreeson in forum Engine & Drivetrain
    Last Post: 25th February 2011, 13:57
  5. limp mode at approx 3000 rpm on 3.0 CDTi SRi
    By Griffi66 in forum Engine & Drivetrain
    Last Post: 18th April 2010, 20:50
