Thread: misfire and crankshaft error codes
    Regular Member shadow.warrior's Avatar
    Jul 2009
    Melbourne
    Default misfire and crankshaft error codes
    hey guys.
    i need the aid of your expertise.
    i drive a manual 3.2 ltr 2004 vectra. even though a service is not due, i have had the little wrench up on the dash for about a month now. So i decided to check the error codes and i got the following:
    P0336 Crankshaft Position Sensor A Circuit Range/Performance
    P0300 Random/Multiple Cylinder Misfire Detected
    P0303 Cylinder 3 Misfire Detected
    P0305 Cylinder 5 Misfire Detected
    the car runs fine, and its definitely got plenty of power. i didnt even notice the misfire.
    also, the car has issues starting when its cold. it will crank but will not fire up very easily, and often will run really rough until i rev it a little. when its warm its fine. its been like this since i got it 1 year ago.
    i have done some research and it looks like these issues may be related.
    can anyone confirm that a faulty crank sensor would cause it to misfire?
    or should i look elsewhere for the cause?
    does this error mean i should change the crankshaft sensor? surely if it was needing replacement i would get the error:
    P0335 Crankshaft Position Sensor A Circuit Malfunction.
    i will be checking and possibly changing the spark plugs on the weekend.
    thanks
    Regular Member LADmachining's Avatar
    Hampshire
    The ECU uses the crank sensor for timing of all engine functions such as injection and ignition. It also moitors the signal from the sensor for minor variations in engine speed that would be attributable to a misfire.
    A problem with the sensor may be fooling the ECU into thinking that there is a misfire. A possibility is the shielding on the crank sesnor wiring breaking down and allowing interference to affect the cranks sensor signal.
    You would be more likely to see the PO335 code if the sensor had gone open/short circuit or was failing to provide a signal to the ECU at all.
    If you only had the misfire codes, I would suggest replacing the plugs or ignition coil pack(s). In your case I would initially suspect the crank sensor itself.
    Jul 2009
    Melbourne
    thanks so much LADmachining. what you said makes loads of sense.
    now, one more question: where abouts can i find the crank sensor? and, is it as easy to replace as it was on the vectra b?
    Regular Member DaveW555's Avatar
    Cannock
    Its on the front of the block on the flywheel side, you'll probably have to get at it from underneath tho.
    Jul 2009
    Melbourne
    thanks dave. when you say the front, do you mean the side facing the front of the car? or the side where the timing belt is?
    Last edited by shadow.warrior; 16th July 2010 at 14:22. Reason: had a few winter ales
    Cannock
    front of the car bud
    Jul 2009
    Melbourne
    for anyone looking for this in the future. its right under the oil filter. you cant miss it.
  1. 3 error codes
    By Hydravox in forum Engine & Drivetrain
    Last Post: 20th April 2011, 12:14
  2. misfire on gas help with fault codes
    By zub in forum Engine & Drivetrain
    Last Post: 23rd September 2010, 17:15
  3. Hello All..... I'm after your help (ERROR CODES)!!!
    By albertoleach in forum Introduce yourself.
    Last Post: 9th March 2009, 09:50
  4. 2.2 Direct misfire codes- help please!
    By mostynmiller in forum Engine & Drivetrain
    Last Post: 27th February 2009, 20:31
  5. Fault/Error code - misfire on cyl 1, 3 & 5
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2007, 20:44
