Thread: Batteries
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default Batteries
    Hi guys, i have a had few problems with the running of my car, finally had the RAC out today and diagnosed the problem as the battery is ******ed. I need to know what the best battery for around £120ish to get that is suitable for the 2.2 dti.
    11 Post(s)
    Buy a new one from over the parts counter at your Vauxhall dealer. Not that expensive and will come with a 3 yr guarantee.
    Jul 2006
    Northampton
    Trim : Sri
    ideally i want a bigger heavy duty one because of the audio but i have thought to just go to vx. do you know how much they are?
    11 Post(s)
    Quote Originally Posted by Danwells72 View Post
    Not offhand, but it shouldn't be any more expensive than any other supplier.
    Easiest thing to do is find your local dealers number and give them a quick call.
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Dont mess about with a standard battery. Get an Optima gel battery. I have one from when I had a big audio set up, then used it as the main battery in my last car. They start at around £120 on ebay these days, i paid a lot more than that when I bought mine.
    http://cgi.ebay.co.uk/12V-OPTIMA-RED...#ht_1402wt_930
    Jul 2006
    Northampton
    Trim : Sri
    Sounds good, it has good starting power but not the same capacity as the gm battery. Does this make a difference?
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 Vtec
    Mileage : 64500
    Not sure about the capacity side of things but these gel batteries work differently to normal lead acid ones like the GM. These are very good "cranking" or starting batteries because they maintain high output a lot longer before falling off, where as a lead acid batteries drop away very sharply. The one I have I bought over 13 years ago. Spent 2 years in the boot as a second battery for my audio system, then went to under the bonnet of a couple of cars over the next 11 years. I only just removed it from under the bonnet of my Accord because I was scrapping the car. It has never ever failed to start any of my cars, Id defiantly recommend one.
    Jul 2006
    Northampton
    Trim : Sri
    I like the sound of it but im just worried about the capacity as i am running an amp but later will be adding more amps so will get a yellow top for that.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    if you go to your local vx dealer they will have loads of batterys on the shelf the best one to go for for a standard look is the battery that fits the 3.0 diesel it is the biggest battery you can fit into a vectra c battery tray ....
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    which I believe is the 85amp one which I've now got fitted.. Its mahoosive!
  1. Key fob batteries??
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2012, 08:26
  2. Key Fob Batteries
    By kompkar in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2010, 21:50
  3. key fob batteries?
    By tonyblade in forum Vectra C / Signum Troubleshooting
    Last Post: 16th February 2009, 21:46
  4. Key batteries
    By Daywalker in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2008, 21:01
  5. Car batteries
    By Ste in forum General Chat
    Last Post: 27th January 2008, 20:33
