Thread: 3.2 v6 gsi lacking in power
    wigan ,uk
    Default 3.2 v6 gsi lacking in power
    Got an 05 3.2 GSi with approx 53,000 miles on the clock and a problem seems to have crept up.
    Car starts fine, idles fine but when you put your foot down to accelerate there just seems to be a lot of induction noise and not much go Driving the car with just light throttle is fine.
    There are no warning lights on or spanners lighting up. I've changed the air filter and that seems to have made no difference.
    Any help much appreciated
    Andy from Wigan
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Blocked main Cat? Its not monitored so can be removed and still pass MOT. Can you take it off and have a look?
    wigan ,uk
    Thanks for the quick response
    is it an easy enough job to patch up with a piece of pipe after removing the cat?
    will it be really obvious once removed whether the cat is blocked?
    WGAF#5
    and spark plugs could be on their way out as well - when were they last changed ?
    wigan ,uk
    just looked through the history of the car and the spark plugs haven't been changed. It's been to the dealers for everything and according to the service manual the plugs don't need doing till 80,000 miles or 8 years but if it stays dry I'll have a look at them this weekend.
    cheers
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    TBH mate I dont know how the Cat is fitted to the 3.2. A couple of members have done the mod with no problems as the pre cats do the MOT work fine on there own. Hopefully they might see this thread with a few pointers.
    WGAF#5
    yep most would change the plugs more regularly to "optimise" performance
    on the old 2.0 i used to change mine every other service
    and my new 2.8 will be getting its second set in the next seven days and has under 30k on the clock
  1. Engine hesitating and generally lacking power
    By Di frost in forum Engine & Drivetrain
    Last Post: 2nd January 2013, 13:02
  2. Vectra "B" Lacking power on take off.
    By felixx in forum Engine & Drivetrain
    Last Post: 14th September 2011, 17:04
  3. 3.2 lacking in power.
    By Hyperhart in forum Engine & Drivetrain
    Last Post: 23rd July 2010, 13:19
  4. lacking power
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2009, 21:47
  5. engine light on,lacking acceleration,2nd and 5th gear manual mode
    By myvauxhall in forum Vectra C / Signum Troubleshooting
    Last Post: 7th April 2009, 10:58
