Thread: Wheel Vibration, replaced, drop links,track rod ends and inner rack ends what next
    Regular Member eaglepva's Avatar
    Up North
    Default Wheel Vibration, replaced, drop links,track rod ends and inner rack ends what next
    Ive got really bad wheel vibration/wobbles at speeds from around 50mph the faster you drive the worse the wobble gets. Ive had the following replaced and its made no differance.
    Drop links, track rod ends and inner rack ends.
    Ive had new tyres fitted and balanced all round and their is no buckled wheels.
    Any help on what to do/try next.
    Mileage : 000
    Perhaps they did not balence them too well. Or one of the tyres is a bit "duff".
    Up North
    Ive been told by a mate that it could be a drive shaft, steering rack or ball joint but dont know how to check these the car has done 80k im going to get all the tyres re balanced again tomorow. Luckily my cousin owns a tyre garage lol
    preston
    Default maybe maybe not
    if this has only happened since your new tyres then....
    swap front to rear
    if it stops then its balancing most likely is problem
    quick check that should only take 30 mins and cost nothing
    from experience had this on mine once.
    it was really sensitive on a pair of goodyear eagles.
    anyway give it a go
    nothing to lose
    good luck
    Regular Member DarylAAS's Avatar
    South Shields
    Yeah had this on my astra... Got a new tyre and had them all balanced and I thort I was gunna get white hand off the vibrations lol... Swapped the tyres round a jobs a goodun...
    Hope this helps
    What tyres has the car been on?
    Do you use the same outlet?
    Go back as far as you can, and highlight when the problem appeared
  1. Drop links replaced - Now bad wheel wobble
    By s1nglef1sh in forum Suspension, Wheels & Brakes
    Last Post: 11th September 2010, 01:30
  2. Track Rod Ends
    By Cat_J in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2010, 01:14
  3. track rod ends
    By sristeven1 in forum Suspension, Wheels & Brakes
    Last Post: 1st July 2009, 12:56
  4. Tie Rods, Track ends, Drop Links...
    By n_hudson in forum Suspension, Wheels & Brakes
    Last Post: 22nd February 2009, 19:20
  5. Drop links and Track rod ends
    By iwoo in forum Suspension, Wheels & Brakes
    Last Post: 29th July 2008, 17:03
