Results 1 to 3 of 3
Thread: oil in air flow sensor
    Regular Member Matt&Jemz's Avatar
    CORNWALL
    Default oil in air flow sensor
    has anyone ever had some oil in there air flow meter
    our poor signum still has a few problems its got oil in the tube from the turbo back to the air flow meter any help you have will will be glady tried
    thanks all
    Full Member Big Sig's Avatar
    Is the turbo ok or is it on it's way out? It could be leaking through the seals. Clean it out and keep an eye on it.
    WGAF#5
    i had the fault on mine once when i first fitted the K&N - too oily - i got some contact cleaner and carefully sprayed the sensor (there are 3 separate wires inside to spray ) then left it to dry and refitted it - disconnected the battery and retested all ok
  1. For Sale: Vectra Mass Air Flow Sensor
    By CraigoT in forum Parts for sale
    Last Post: 25th September 2012, 22:59
  2. mass air flow sensor
    By vectra craig in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 19:53
  3. Mass Air Flow Sensor
    By stroake in forum Engine & Drivetrain
    Last Post: 13th May 2009, 15:40
  4. Mass Air flow Sensor fault
    By stroake in forum Vectra C / Signum Troubleshooting
    Last Post: 12th May 2009, 12:34
  5. Air flow sensor...
    By dankidd in forum Engine & Drivetrain
    Last Post: 31st August 2008, 17:28
