Results 1 to 10 of 14
Thread: Removing particulate filter
    woking
    Default Removing particulate filter
    Hi all having just had my particulate filter cleaned and erg replaced and now got an empty wallet iv herd on here peeps saying they have had the cat replaced with a straight through pipe.
    To my understanding the cat is in the particulate filter so here's my question did you have any problems putting the vacuum pipes and sensor in the particulate filter in the straight through or do you need a remmap to have a straight through exhaust?
    Depends if it's a diesel as some have a diesel particulate filter as well as a cat.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Hi basically you hav a cat and a particule filter or dpf as they are known
    The cat is bolted on to the turbo then exhaust bolts on to
    the car and the dpf is fitted in the mid section with 2 pressure pipes and one temp sensor
    Basically in short to remove the dpf ad software to stop it doing regens you need to get the dpf removed from th cars ecu which is about 100-180 depending on where you go once removed then you can replace with a straight through pipe and either cut the pipes and sensor off or tie them up out the way
    The cheap way to removing it is to take out the dpf smash the insides out so it's a hollow can then refit ad follow the smaller diameter pressure pipe to the bulkhead of the engine bay it goes
    into a little black box looks like a match box size it is to the back right o the engine bay below the engine coolan bottle it has a plug and 2 pipes into the bottom take the smaller pipe off the crimp it over it's self and cable tie it so no air can escape thenstart your car up ad there will be no engine light on and you will have no dpf but apparantly every now and then it will do a regen which will result in alot of smoke but another person I know does not have regens after doing this so you will have to try to find out
    As for the cat you can remove this no probs either welding in a de cat pipe or smashing the insides out then refitting it and it has no sensors so no probs there
    Hope this helps mate
    woking
    It a 1.9cdti 150 with a crd-t fitted. Thanks Winnie that's helped clear up a few things will removing the dpf and cat make much difference as the dpf looks very restrictive!
    kings lynn, norfolk
    Will make a massive difference mate as dpf is very restrictive
    You will see a rise in mpg and better performance
    I de catted a mondeo tdci and it was the best mod I did and I will be removing the cat and dpf from mine soon too
    woking
    Who does the software to wipe the dpf?
    kings lynn, norfolk
    Type into google dpf removal softwareL and there are a few companys who do it And I know of a company in Newcastle but quite a trek have a search on google is your best bet
    Regular Member bothyboy's Avatar
    Nov 2009
    Herefordshire
    Great advice, though seems obvious to me now - doh! I'm having serious DPF issues (see contributions here http://www.vectra-c.com/forum/showth...+filter&page=3). Just found a remap firm in Cannock and sent them an enquiry, so may well go down this route and rid the Vectra of this work of Satan!
    PRESTON
    http://www.dpfremoval.co.uk/ might be worth a try, i haven't used them myself.
    kings lynn, norfolk
    Hi Barney I rang them they are very expensive they quoted me 350quid to just remove the dpf software
    Cheapest place I have seen for dpf software removal is pdtuning in Newcastle upon Tyne but they do have 2 franchise is Lincoln and London the price they quoted menwas 150 quid which is cheap
    If you ring the main Newcastle number and speak to them about there Lincoln and London branches they can arrange to get it done there hope this helps guys
  1. Particulate Filter Problem again
    By phil67 in forum Insignia car chat
    Last Post: 27th April 2011, 14:23
  2. Diesel Particulate Filter
    By bafoo in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2011, 18:06
  3. Diesel Particulate Filter Re-gen
    By RobertHayman in forum Engine & Drivetrain
    Last Post: 16th November 2010, 23:47
  4. Diesel Particulate Filter or not??
    By Drew in forum Engine & Drivetrain
    Last Post: 26th January 2009, 09:32
  5. Diesel Particulate Filter
    By Eddie Dee in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2007, 20:10
