Thread: Not The Normal Wiper Fault....
    Regular Member DarylAAS's Avatar
    South Shields
    Default Not The Normal Wiper Fault....
    Well the car has gone in today for a new inlet manifold... egr valve ... and the heater problems (only working on 4).... But i noticed this morning when it was raining the first time since i had the car... but wipers work on low and medium settings... but if you put it onto the highest setting its stops instantly... so its just like it tells it to switch of...
    Any Ideas....
    Regular Member denzilbud's Avatar
    cambridge
    is this not the heater motor resistor
    South Shields
    .... are they connected like... i know the heater resisters have gone obviously as the heaters arent working but didnt think they would interfere with the wipers...
    cambridge
    totally mis read post my mistake sorry
    cambridge
    i have kind of the same problem with my wipers as said first 2 settings fine but last setting my wipers go mad first real quick then slow down and this carrys on till i select one of the other settings,i resort to using single wipe unless its hammering down,so interested in finding a solution too
    cambridge
    type in wiper problem and read the thread that manunut1969 posted could help,i would link it but not sure how to
    Mar 2007
    Surrey
    Got the same problem as op with mine... bought a new wiper motor today from vx and fitted it.. issue still exists!.... so have put back the old motor now..
    Checked all the fuses... all fine...
    Worring about what else the problem could be..
    Any thoughts anyone?
    Quote Originally Posted by denzilbud View Post
    http://www.vectra-c.com/forum/showthread.php?t=109800
    South Shields
    But our fault is the other way round... If the garage don't do anything about it then al speak to my mate who is a local vaux tech... And see what he says...
    Mar 2007
    Surrey
    OK. Update..
    Found a fuse in the engine bay. F22.. had blown.. Replaced that, fitted the old motor and it wouldn't go faster than slow.. but I could hear it straining as it was trying to go faster but couldn't. Fitted the new motor, and after nearly severing my thumb in the process, voila.. working fine.. (although £85 worse off)
    Worth checking out Fuse F22 next to the battery.
  1. Intermitent & Normal Speed wipers not working, Some help establishing fault plz??
    By MK SRIVECTRA in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2012, 11:51
  2. Replies: 3
    Last Post: 31st May 2012, 09:41
  3. Different from the normal wiper issue
    By Jebus in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2012, 22:07
  4. Y30DT Looses boost, clear fault code and back to normal!
    By tommychimp in forum Y & Z30DT Specific
    Last Post: 5th September 2011, 20:07
  5. wiper fault
    By bembo449 in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2011, 07:38
