Thread: please help
    Jul 2010
    berks
    Default please help
    i cant access the problem page and i need some advice before i call the dealer
    i used to have a vectra gsi that i sold a year or two ago and need a run a round for the dog etc so went and bought a vectra b 1998 2.5 v6 cdx auto estate and the climate control has stopped running properly
    it all lights up, you can select high to low on the blower, high to low and all the temperature in-between but it will not blow HOT air
    i have looked at the fuses and all seem ok, even thought it might be the front control panel as the back lights were not working so bought a replacement off ebay and that all works fine now but still no hot air
    i have found that there are like 6 valves in the system, could one of them gone?
    if so other than putting it into the dealer and hooking it to a diagnostic machine is there are common valve or sender that goes that can be easily replaced
    please can some one point me in the right direction i would really appreciate it
    thanks
    steve
    Essex
    Look in the drivers footwell, behind the centre console, you kind of have to stand on your head.
    There are a couple of actuator arms that go vertically upwards, one of these had come off on mine and it then only blew cold.
    with the car warm and the fan going if you move this bar by hand you will feel the warm air, i was able to reattach the bar and this resolved the problem
    Good luck
    Jul 2010
    berks
    cheers any idea which one is for the warm air?
    Essex
    On mine it was the one that wasnt connected at both ends!!
    Quote Originally Posted by stevie1982 View Post
    Process of elimination
    Jul 2010
    berks
    Quote Originally Posted by simon11244 View Post
    ha fair point,
    Jul 2010
    berks
    silly question but i take it one is for the cold and one for the hot?
    anything else i can try whilst i am at it
    Essex
    No, when its up its hot when its down its cold in between is warm!!
    Jul 2010
    berks
    ok i assume by up you mean towards the windscreen?
    and you say there is two actuators, one is the heater what is the other for?
    Essex
    Sorry i have no idea what they are for (or if the 2nd is definately there)
    I just recall i had the same problem on a CDX the winter before last, when it was at it coldest and this fixed it.
    Best thing to do is to have a look see if there is something disconnected on that side, if there is thats your problem if not I dont know.
    I dont have the car any more so am unable to check anything. But it is obviously wrong when you look
