Results 1 to 3 of 3
Thread: Fitting A Rear Bumper ?
    Regular Member The Gas Man's Avatar
    Feb 2006
    north east
    Default Fitting A Rear Bumper ?
    hi all anyone know how easy it is to fit a rear bumper as i am changing my standard type for the sri type. thanks
    Admin plasma's Avatar
    On the Forum
    313 Post(s)
    Engine : 150
    Mileage : 74000
    easy peasy,
    remove rear lights from car, 3 x nuts each,
    undo 2 torx screws by each rear wheel arch/bumper edge.
    2 x torx screws to remove from number plate recess,
    then carefull pull the edge of the bumper away from the wheel arch, you'll see that is pops out. Careful near the corners because it can split a bit.
    Press down on the tabs and slide out the tongue on the bumper corner away from the moudling on the bodywork with a flat blade screwdriver or something that wont scratch it, once each corner is free gently pull the bumper towards you to free it from the friction clips and its off!
    Feb 2006
    north east
    great thanks a lot
  1. Help fitting the rear bumper.....
    By sinless in forum General Motoring Chat
    Last Post: 5th December 2012, 00:10
  2. Fitting aftermarket parking sensors to XP 'd rear bumper
    By 2.2 oil burner in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2012, 22:45
  3. Replies: 5
    Last Post: 5th February 2012, 20:42
  4. Rear bumper removal for towbar fitting
    By Neil71 in forum Insignia car chat
    Last Post: 16th February 2011, 15:57
  5. rear bumper remove/fitting
    By armoured farmer in forum Bodywork & Interior
    Last Post: 7th November 2005, 13:47
