Thread: Help With Fuel Filter
    Regular Member lutontownfan's Avatar
    Nov 2009
    colchester
    Default Help With Fuel Filter
    Am in the middle of trying to unscrew the filter case on a 150 cdti the arrows are showing to unscrew it clockwise?? its as tight as heck. Does anyone know the correct way to undo this so i can change the element? Thanks
    york
    go against the arrows they are to tighten i found best way was put it in a clamp not too tight and use a hammer and blunt punch
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    this thread may help
    http://www.vectra-c.com/forum/showth...el+filter+cdti
    careful not to break this thing, expensive to replace.
    Nov 2009
    colchester
    ok will try to undo it i have a three legged remover to help but i dont have a vice to clamp it into. Thanks for help.
    Nov 2009
    colchester
    Have got it all put back but when starting up there is fuel leaking from the bottom of filter. worried now does it have to be real tight when screwing back up have taken it off again and not sure why its leaking i put the new seal on it
    swansea
    You may have overtightened it and distorted the seal.
    Nov 2009
    colchester
    Panic over, i took it off again and re seated it reconnected everything and its not leaking now.....thank you for all help.
  1. Replies: 19
    Last Post: 30th May 2012, 15:53
  2. Fuel filter help
    By wolvesdaz in forum Engine & Drivetrain
    Last Post: 4th March 2011, 10:47
  3. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
  4. fuel filter
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2007, 23:27
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
