Results 1 to 10 of 21
Thread: Electric Tailgate Faulty????
    Jan 2010
    wirral
    Angry Electric Tailgate Faulty????
    Please help me, I have a 56 plate vectra design estate, and I am unlucky enough to have the optional extra of an electric tailgate.
    Problem is, it won't close fully via button on the tail gate OR the key fob.
    Its almost as though its sensing some kind of resistance, half way through its closing cycle......it just stops, waits approx 10 seconds, then opens fully again.
    It has done this in the past and then somehow righted itself, but just lately, it ain't playing ball!!
    Is there some kind of safety sensor on it, if so where??
    Or does it need some tech 2 type intervention??
    It opens fine, just as it should, I have checked for anything that may be in its way during closing.....in fact, i have emptied the boot completely.
    Its yankin me chain now!!!!!!!!!!!!!!!!
    May 2007
    West Yorkshire
    I have an 08 plate Elite with the same issue, (closes ½ way then stops) took it to the dealers when it did it for a full day, they spent an hour on it and asked me to book it in for a full day. Booked it in and they said it was fault free on the day! I know it was fault free it's intermittent and that's why I insisted they look at it before so they could see when it does it (only 3 days over the last year.) Any way that was two months ago and up to yesterday it has been OK but did it twice in the morning. Good luck and let me know how you get on.
    Jan 2010
    wirral
    Nice one,
    Its not the end of the world, in fact it nothing compared to the other problems i'm having. I just feel as though I'm doing it harm when I have to "force" it shut manually!!
    Plus, when I press the remote to close it, I find myself standing , waiting, just to see if it actually closes itself!!!
    PRESTON
    ditto bafoo, my estate does the same from time to time. the safety sensor is the potentiometer attached to the side of the operating motor in the rear quarter, could be intermittant fault on that. I know what you mean about resistance when attempting the manual close and i found pushing it closed using short jerky pushes seems easier, no comments about short jerky pushes, LMAO
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    they use a plastic gear that sheers off teeth slipping. repair is a complete motor
    PRESTON
    would that cause the intermittant issue matt? when mine does this about every two to three months i cant hear any motor ginding sound, it just stops, like it should when it encounters resistance, then will be fine for a couple of months.
    Regular Member bothyboy's Avatar
    Nov 2009
    Herefordshire
    Quote Originally Posted by bafoo View Post
    Nice one,
    I have this too from time to time, but just got a alot worse. I too stand watching it see if will close, son and I take bets on this usualy - sad but true!
    I Also have other issues (DPF) and as can still close manually I will not be wasting time and money on it - other than occassional wd40 treatment.
    Apr 2009
    Northants
    Default 2008 Vectra Power Tailgate not closing properly
    Hi all,
    My 2008 Elite has just started doing this . It stops about half way and all you can do is push it the rest of the way.
    Has anybody managed to confidently identify the source of this issue please?
    I have seen posts mentioning potentiometer problems / stripped gears etc, but despite the seemingly large number of people having this problem I have only seen one confirmed fix (and that was potentiometer)
    I have a Warranty Direct policy on car which should cover this, but Warranty Direct suspect that their network of garages won't be able to diagnose this kind of fault. I'll give them a go but figured any other info I could supply might be useful!
    Any help would be appreciated!
    Many thanks,
    Dave
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    its a new "Potentiometer" is needed.
    cost about 60£
    Apr 2009
    Northants
    Quote Originally Posted by kenp View Post
    cost about 60£
    Thanks for your quick response!
    Is this something I could change myself (I'm a fairly technical type who can follow instructions), or something to be done at the garage?
    Also, is p/n V0093190877 correct as I searched for this and couldn't find it
    Many thanks again
    Dave
  1. Electric tailgate opens itself
    By lastyboy in forum Bodywork & Interior
    Last Post: 10th November 2013, 19:42
  2. Astra H electric tailgate question
    By dannycturbo in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2011, 10:51
  3. Estate Electric Tailgate
    By chaddopete in forum Bodywork & Interior
    Last Post: 3rd August 2011, 16:21
  4. faulty electric tailgate switch
    By admob in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 12:43
  5. Electric tailgate retrofit?
    By Scalesy in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2008, 21:46
https:www.vectra-c.comforumshowthread.php114987-Electric-Tailgate-Faulty
vauxhall vectra estate electric tailgate button fault
vectra c electric tailgate only closes half way
vectra c electric tailgate repair
vectra electric tailgate sticking
vectra 2008 electric boot
how to reset electric tailgate vauxhall insignia
vectra 2007 estate electric tail problems
vauxhall insignia estate tailgate problems
electric tailgates problem
vectra elite boot motor
why wont my vauxhall electric boot close
insignia power tailgate not working
how much to replace vectra c electronic tailgate motor
vectra 2006 powered tailgate not working
insignia electric boot problems
vauxhall vectra estate electric tailgate problems
electric boot on stepwagan not working
vauxhall insignia estate electronic tailgate
reset vecta electric boot
Vectra estate rmoving power tail gate
vectra c boot lid not working properly
opel eletric tailgate
vectra boot only closes halfway
