Thread: Brake pad wear sensor
    Fife
    Default Brake pad wear sensor
    I'm needing to fit a new wear sensor when I change the front pads on a pre-face 1.9cdti 120 Sri.
    However, there are two types available, one with a cable length of 685mm and one with a cable length of 298mm.
    http://www.eurocarparts.com/ecp/c/Va...d-Wear-Sensors
    Anyone know which one I should be getting?
    Cheers.
    PRESTON
    the shorter cables were used on vehicles built after 2004, from chassis number C 41048790 and C 48045598
    Fife
    Thanks mate. it's an 05 so I'll get the shorter one.
    PRESTON
    just check your chassis range. if your car was registered 05, theres an outside chance it could still be an 04 model. If you want to pm me your reg number, i can confirm on EPC for you.
  1. Brake wear sensor. Should my car have one?
    By Big Dave in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2013, 10:40
  2. Brake wear sensor put where?
    By kenp in forum Suspension, Wheels & Brakes
    Last Post: 28th August 2012, 23:33
  3. brake wear sensor
    By dazza2393 in forum Suspension, Wheels & Brakes
    Last Post: 17th June 2010, 22:30
  4. Brake wear sensor
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2008, 20:33
