Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Z22YH EGR Blanking
    Nov 2009
    surrey
    Default Z22YH EGR Blanking
    Hi everyone,
    I noted the part number for th above engine for the blanking plate : 55562899 Catalogue No: 851144.
    Now when this is fitted, what happens to the 2 holes left in the inlet manifold. Do these all come in a kit?
    Also, can you leave the EGR secured in the engine bay, or must I get a ECU download with latest software, which in turn ignores the EGR.
    Thanks for any help
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I've posted in your thread on the 2.2 forum mate.
    Nov 2009
    surrey
    Thanks, I'll have a look.
    glasgow area
    Hi there
    Just called VX dealer to check the price of the EGR blanking plate for my 2.2 Direct's Z22YH engine and they told me it's £38.94!!! My mate got one a couple of months back for his Z22SE and it was only about 4 quid!!! It's just a dod of steel with 2 holes in it!!
    Are Vauxhall now just cashing in now that car owners have twigged that we can bypass the EGR???
    Bonkers if you ask me.
    Davie
    glasgow area
    Oh aye - it was part number 55562899 like you said justathome...
    Vehicle : SRi
    Mileage : 137000
    It's a totally different thing mate as the yh egr is water cooled. There is a cheap method though that involves a coke can.
    glasgow area
    Cheers Rushy. I see! 2 completely different systems. Fair enough then! I'll stop moanin'! Need to get a closer look at this then if there's water involved! EEK!
    Thanks for the help mate
    Davie
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by DavieM View Post
    Davie
    Are you wanting to get round a broken egr or blanking it to protect the manifold/solve running problems? If it's the latter then the other method I mentioned could be right up your street as it blanks the egr system without even going anywhere near the egr.
    I'll post a picture when im on the pc rarther thatn phone.
    Vehicle : SRi
    Mileage : 137000
    You can make a plate and sandwich in in between the head and the EGR outlet pipe here mate.
    Its pipe #1 that your blanking in this pic to the manifold.
    If the EGR is broken however its a little more complicated and the GM part would be needed.
    HTH
    Steve
    glasgow area
    Well! Now that you ask! The car's not been running very well for quite some time now. I have this intermittent - all of a sudden it'll start running on 3 cylinders and the only way to get it back on all 4 is to turn off the engine and turn it back on again. There's no set pattern to this. It's random. And the idle is very rough. I had it at my wee local garage and they've replaced the coil pack twice (Diagnostics said "misfire, cylinder 1") but it's still not right. I also had to replace the hp fuel pump less than 2 yrs ago and got the regulator replaced under warranty a 3 months ago. i want to blank off the EGR as it seems it's not really necessary and allows all sorts of gunk into the inlet, which is not exactly ideal. My mate blanked his EGR off on his Vec B 2.2SE engine and it runs much smoother than before and the flat spot's far less noticeable around 2K revs.. I now suspect that perhaps the EGR has allowed so much muck in it may have clogged the swirl valves... ?? What do you think?? So for me, I'd like to get the manifold off, clean it, and blank off the EGR. Oh yes - my engine light's been on for months.... Oh joy... :-)
    The car's now done 83K miles and I've had it since 1 yr old with 16K... Davie
  1. Z22YH EGR Mod??
    By Stevie76 in forum Engine & Drivetrain
    Last Post: 31st December 2011, 20:06
  2. i need part number for egr blanking plate 2.2 direct Z22yh
    By tattootroy in forum Engine & Drivetrain
    Last Post: 29th July 2010, 18:01
  3. Z22yh....EGR???
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2010, 12:23
  4. Egr - z22yh
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2009, 12:07
  5. Z22SE vs Z22YH
    By Jason123 in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2009, 23:19
z22yh egr blanking plate
z22yh engine tuning
Vectra 2.2 petrol egr blank
z22yh egr software
egr blanking plate vectra c 2.2 direct
egr blanking z22yh
egr blanking pipe z22yh
egr cheater z22yh
z22yh egr off
how do you blank of the egr on a 2.2 petrol vectra c
blank egr on z22yh
vectra c Z22SE egr blank plate
z22yh egr valve cleaning
opel vectra plate 55562899
z22yh
