Thread: Coolant capacity
    Regular Member blackveccyC's Avatar
    Dumfries
    Default Coolant capacity
    Hi folks I've done a search but can't find the answer i'm looking for.
    Does anyone have the coolant capacity for the z18xe engine? either that how much is left in the engine after draining from the radiator and the thermostat, as i'm doing a clean flush with garden hose as the stuff thats in is nearly like water.
    Much appreciated guys
    TIS states 5.5 litres in the system, you should use Anti-freeze 19 40 650/09 194 431 (red)
    Its the VX long lift stuff. I put at least a 50:50 mix in mine last time.
    Dumfries
    grand mate cheers for that, so if i were to flush system clean then add 2.75 litres of coolant then top up with water until it reaches kalt mark, job should be a good one? then obviously keep an eye out for the water dropping. Will have a stab at it tonight.
    The concentration thats recommended is normally on the back of the bottle. With the thermostat in its difficult to flush the system completly but doing it with a hosepipe will fluch most of it out
  1. Coolant capacity? 2.2 Direct auto
    By Big Dave in forum Engine & Drivetrain
    Last Post: 24th February 2012, 17:52
  2. oil capacity
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2010, 15:53
  3. oil capacity
    Last Post: 27th August 2009, 00:26
  4. OIL Capacity on 2.2
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2008, 13:16
  5. oil capacity
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2008, 10:32
vectra c coolant capacity
opel vectra 2007 coolant capacity
coolant capacity vauxhall zafiraz18xer coolant capacityvectra c antifreeze amounthttps:www.vectra-c.comforumshowthread.php114974-Coolant-capacityvectra c how much coolanthow many litres of coolant in a vauxhall zafira 1.6 holdcoolant capacity 07 vauxhall zafiraopel vectra cooling system capacitycoolant capacity vectra c57 plate vauxhall vectra how much coolant does it holdvectra c antifreeze amoutVauxhall vectra c radiator litreshow much coolent in a vauxhall vectra cvectra sri 1.8 how much coolanthow much coolant need to z18xer09 194 431 coolantvectra c 1.8 how much coolantvectra c radiator capacityvectra c 1.8 coolant capacityzafira coolant capacityvectra how much coolanthow much coolant do i put in my vectra cvauxhall vectra c 1.8 radiator capasity
