Results 1 to 10 of 15
Thread: lowering my sxi
    Regular Member hazel's Avatar
    Scotland
    Default lowering my sxi
    hello... just fitted new 17`s looking at lowering now ,
    I`m happy with the ride comfort just the GAP is really visable now ,
    could i just fit lowering springs (keeping the standard shocks),
    I`ve read einbech (spelling) springs are good for what i need just need some other options, price ,how far to lower, cost of springs cost of fitting...ect
    oh yeh its a 2004 sxi 1.8
    thanks Hazel
    Regular Member jonno_07's Avatar
    Apr 2006
    beverley
    these are quite a good buy and should fit nicely
    hth
    ifIf it’s a non sri specced 'sxi', ie fitted with normal springs and non sri bumpers then I'd go for standard issue sri springs. It will lower it just the right amount, still be a Vauxhall part which they probably wont even notice under warranty, and it maintains the ride comfort. Worked a treat on my Elite.
    Regular Member Matt21385's Avatar
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    I have a full set of Sri suspension for sale (£60) if interested?
    Scotland
    Hi Andy... mark here Hazels other half
    it`s a 53plate 04 and has normal bumpers and a huge gap between tyre and arch so I assume it`s a non sri sxi..
    will standard issue sri springs go streight onto/over my shocks, if i take Matts full set of suspention can i just use the springs... thanks for your help
    Matt very interested just need to know it`ll fit mine (fingers crossed)
    thank for replys guys cheers Mark
    Dec 2005
    In the sponge-monkey tent
    You might get away with standard Vx SRi springs, but be careful using other aftermarket springs that give you a drop of 30mm or more. As I found with mine, the standard Vx shocks do not work correctly with lowering springs. If you want to lower the car then my advice would be to look at both springs and shocks being changed together, there's plenty of kits around for the Vec-C now and the only real restraint is how much money you can afford to spend on it.
    Regular Member JYsV6's Avatar
    Dec 2005
    CUMBRIA
    Also been contemplating replacing the springs on my 3.2 elite to improve the ride/handling. Seen Andy's previous posts about fitting SRi springs, but are all SRi springs the same regardless of which engine is fitted?
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Quote Originally Posted by JYsV6
    Think the springs have to match the weight of the car, not sure though. Someone will correct me if im wrong
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    Your correct Matt, axle weights have to match the spring ratings.
    And i bet Jonno see this and is hot on my heels replying to it!
    Apr 2006
    beverley
    your right matt, the weight has to match the spring ratings
  1. Lowering on the sri.
    By Roy_Vec in forum Tuning
    Last Post: 13th September 2009, 09:15
  2. Lowering again
    By Ziggy in forum Handling & Braking
    Last Post: 2nd June 2009, 14:19
  3. Lowering
    By euro-dee in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2009, 01:22
  4. Lowering
    By s1nglef1sh in forum Handling & Braking
    Last Post: 6th November 2008, 22:46
  5. lowering???
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2008, 23:49
