Thread: Black smoke from exhaust - YAHOO ANSWERS
    KENT
    Default Black smoke from exhaust - YAHOO ANSWERS
    Hi
    Im still having black smoke pump out when I move off from junctions etc.... I found this on YAHOO ANSWERS. What do you think.......
    QUESTION
    Vectra 2.0 dti 2003 reg excessive black smoke from exhaust ?
    i have had my car for about 1 year and up until 8 weeks ago all was well then suddenly it started to kick out excessive amounts of black smoke from the exhaust when hard revved or underload. i have tried everything by taking it to a vauxhall mechanic and it was put on the computer and found no faults. i have replaced the engine, airflow sensor, and turbo to no avail. i have spent s**tloads of money and still the problem is there , please can someone help me as i am at my wits end with it thankyou.
    ANSWER
    Tony C
    Best Answer - Chosen by Voters
    You really are'nt going to believe this but humour me. There is a fault on the vauxhalls that you are having that is caused by the brakelight switch going faulty, ask your vauxhall mechanic about it.
    Source(s):
    I'm an auto- electrician and have heard about this fault, only once but it is a rare fault that not a lot of people know about. Hope this helps.
    What do you think? anyone else heard of this???
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    The answer is 'voted' - says everything as far as i'm concerned really.
    My Vectra wont even start unless all of the lights are left on in my house
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    Then on finding it:
    http://uk.answers.yahoo.com/question...3140256AAHxNRO
    It looks like the only answer
    Gazza4
    Regular Member eaglepva's Avatar
    Up North
    Have you checked the big hoses for splits or cracks, as this can cause black smoke when pulling away.
    Apr 2008
    High Wycombe
    Vehicle : Vauxhall Insignia
    Trim : SRI NAV
    Engine : 2.0 CDTI 140
    Mileage : 20000
    I dont have a great deal of smoke from my Signum as its fitted with a DPF, but I've had probelms with Limp Mode kicking in which has been diagnosed as the Throttle Body.
    I've used Wynns EGR3, and I've just tried Forte Air Intake Cleaner to give it all a clean. Not sure if using something like this would help clear the smoke?
    Worcs/Staffs/Westmids (ish)
    Quote Originally Posted by 123ashleyp View Post
    Hi
    QUESTION
    ANSWER
    Tony C
    Source(s):
    You should check your front OS tyre is correctly inflated. I have a mate who's a fully qualified "vehicular road contact management engineer" (tyre fitter).
    He said that under inflated tyre's can cause the tyre's to overheat, the tyre smoke gets sucked into the engine and comes out of the exhaust!
    Well actually thats a rough translation as he only know's the word "tyre's".
    He's a genious though and uses different vocal tones to distinguish what he's talking about.
    "Tyre's" in a low voice is very bad apparently
    "Tyre's" in a high pitch means something good has happened
    "Tyre's" with a pointy finger means "your brakes need replacing mate"
    "Tyre's" in a slightly slurd voice means "can I have a pint of special brew please?".
  1. Replies: 22
    Last Post: 5th September 2012, 13:25
  2. Vectra 1.9CDTI(120) Black Smoke Exhaust.
    By Nucleo in forum Engine & Drivetrain
    Last Post: 14th February 2012, 11:09
  3. air box mod / black smoke
    By Guss in forum Diesel Engine related
    Last Post: 22nd August 2011, 15:25
  4. Two recordings of my exhaust and black smoke
    By george1987 in forum Diesel Engine related
    Last Post: 14th June 2010, 17:28
  5. Black Smoke
    By ivo_88 in forum Troubleshooting
    Last Post: 17th July 2008, 11:32
