Results 1 to 10 of 13
Thread: what can carburettor cleaner do?
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default what can carburettor cleaner do?
    right ive brought some carburettor cleaner to do my egr valve tomorrow ill do boost sensor aswell, can i spray the carburettor cleaner to clean any other parts????
    also ive hurd that people have reved the car when the egr is off so the muck comes out of the manifold is this correct??
    2.0dti engine
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Personally I spay it onto the egr valve and boost sensor when these parts are completely off of the engine - that way should there be any engine issues I can a bit of relief knowign that one of those parts are damaged.
    My reason for not spraying it into the manifold is it can dislodge the crud in there and this may block the manifold.
    Gazza4
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    As above with the tips for cleaning the EGR and boost sensor , also remove the manifold that the boost sensor sits in and clean the butterfly mechanism inside
    Oct 2009
    Sandwell
    Quote Originally Posted by bobssignum View Post
    is this hard to do how long should it take to get off?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by chris1804 View Post
    Check the how2's
    Gazza4
    Oct 2009
    Sandwell
    Quote Originally Posted by Gazza4 View Post
    Check the how2's
    Gazza4
    theres a how2 for this for the dti?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Sorry I thought is was a 1.9CDTI you had,
    Here is the EGR Valve how2:
    http://www.vectra-c.com/forum/showthread.php?t=60856
    Gazza4
    Oct 2009
    Sandwell
    Gazza4
    cheers mate i used that to clean the egr last time, what ill do is get some rag soke it in carb cleaner and try and clean out the manifold where the egr goes, do ya think that will be ok?? gonna get some of that 10k boost stuff i think
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    if you use little as possbile you should be ok but I would watch what you do manifold side whatever you do as dislodging the rubbish in the manifold will cause headaches if it clogs it up.
    Gazza4
    Oct 2009
    Sandwell
    Gazza4
    sod it ill just do egr and boot sensor because im one of these ill try and clean it and end up ****ing it up and then saying why did i touch it for, i think the manifold is best left alone lol
    i only do about 4 miles a day less than that prob so my car could prob do with a good blast at high revs to get rid of all the ****
  1. Air con cleaner
    By themarbleman in forum General Motoring Chat
    Last Post: 18th March 2012, 21:46
  2. Carb Cleaner / Inlet Cleaner 150 CDTI
    Last Post: 19th July 2011, 09:50
  3. air con cleaner
    Last Post: 6th November 2010, 20:17
  4. Gets cleaner and cleaner shinier and shinier over time..wow
    By hertscol in forum Quick Photo Album
    Last Post: 25th September 2009, 08:10
  5. Replies: 7
    Last Post: 2nd July 2009, 17:51
