Thread: What Size.....?
    Derbyshire
    Default What Size.....?
    Ive got a 58 plate 1.9 120.
    Could someone please tell me what size the front and rear breaks would be please
    Thanks in advance
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    brake discs?
    Derbyshire
    Quote Originally Posted by Grimo72 View Post
    brake discs?
    Thats right, brake disc size for the front & rear please.
    Full Member Penfold101's Avatar
    Fronts are 285mm, rears are 278mm...
    Derbyshire
    Quote Originally Posted by Penfold101 View Post
    Fantastic! thanks very much! i'm after some drilled and grooved ones you see.
    if there any sort of bigger caliper upgrade that i can do on it as well?
    off the V6 version or something?
    Yup, 314mm fronts from the V6 models, 345mm fronts from the VXR, and 292mm vented rears from the 2.0 Turbo and V6's.
    All require different calipers and carriers - scrappies are the best bet...
    Derbyshire
    Brilliant, thankyou very much for your help fella!
    might have to get my ass round the breakers yard!
    Disc and pad kits are cheap as cheaps from the dealer, except for the VXR ones which are horrendously expensive...
    Part numbers are in the Part Number section...
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    There is a full set on Ebay at the moment.
  1. 1.8 alt what size?
    By MiniVauxhall in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2012, 16:19
  2. Wheel size and tyre size
    By DSmiddy in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2011, 19:19
  3. What size is it??
    By simmo3187 in forum Styling
    Last Post: 22nd April 2011, 23:33
  4. What size, are?
    By Ean in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2009, 21:26
  5. Size of tid?
    By seanyis in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2008, 11:29
