Thread: Weird power steering issue
    Ireland
    Default Weird power steering issue
    Hi all,
    My power steering works perfectly when I need to go right (turning the wheel clockwise). But when I need to go left, if I turn the wheel with a bit of speed it stiffens up as if the power steering isn't working for a second. This feels the same if the car is at a standstill or moving slowly. Any ideas? Fluid level seems fine. I'm guessing some belt is acting funny?
    Regular Member mitch's Avatar
    WIGSTON, LEICESTER, LE18
    daft question have you checked your front tyre pressure?? if low then that could make steering heavier / stiff
    Ireland
    Yip tyre pressure is spot on - thanks for the suggestion though!
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    suffering exactly the same with same car
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    could be low on fluid
  1. Power steering issue.
    By frankieboy1 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd January 2013, 23:41
  2. power steering issue
    By Baldwin in forum Vectra C / Signum Troubleshooting
    Last Post: 26th October 2012, 21:58
  3. Power steering issue
    By danhariga in forum Engine & Drivetrain
    Last Post: 18th August 2012, 22:48
  4. Power steering issue
    By MIAMI in forum Vectra C / Signum Troubleshooting
    Last Post: 21st September 2010, 21:05
  5. power steering issue
    By myelite150 in forum Engine & Drivetrain
    Last Post: 8th September 2010, 14:54
