Results 1 to 10 of 30
Thread: Crank case vent
    Sodding Typical on Sea
    Default Crank case vent
    OK now I have been running a modified CCV (as per Winnie2457 lengthy post on the subject) venting through a small metal filter adjacent to but just above the ARB, for about 2,000 miles now and can report that the intake system is totally immaculate not had any fume ingress and not had any increase in oil consumption.
    I think I am going to leave the set up alone for now and call it a success!
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Just to back you up there derek mine been on 5000 miles now and no loss of oil and intake dry as a bone no oil or cruddy build up I am now the same as you venting through a small metal breather next to the arb
    Only good results so far and I am suprised the amount of fumes and smoke and heat that comes from re breather no wonder your intake manifold is
    clogged up an you get less mpg with it connected due to the heat and smoke meaning less cool fresh air
    Any one else to report on this mod I knownthere are a few other ppl who hve tried it out
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    I would like to try this, but would need an idiots guide to how to do it... any takers...?
    Definitely this and EGR blanking is a must on the CDTi for longevity.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    EGR valve is a blanking for me @ remap time but as for the oil catch tank - well my luck being my luck I would endup disturbing something and awakening a load of grief, but I will deffo say the oil catch tank idea is a peach of an idea.
    Gazza4
    No Problems can do a photo how to if you like?
    I also plan on the Fiat restricted gaskets shortly too.
    As for economy it is up from 50.4 to 51.3 in similar motoring so seems not to have any negative impact on fuel
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by Derek Mc View Post
    That would be great mate.
    Same with me with the completely blanked EGR, slight increase in mpg has been the result, used to scrape 60 on a long motorway run, but can now get low 60's every time
    OK, I have borrowed a pic from Winnie2457's post to illustrate what I am talking about.
    1. Remove the pipe that exits from the oil separator that goes in to the metal crossover pipe remove it and replace it turned round to give clearance to the extension you are about to add. Use a jubilee clip to seal it back in the new position.
    2. Get hold of about 1m of 1/2" or 13mm oil/cooling type hose from a motor factor and a connector to join to the hose then route the pipe along the bulkhead and then down to the passenger side foot-well in my case just above the ARB so that fumes are not drawn in to the cabin and it doesn't get wet in a water "fording" situation as I used the height of the engine intake as a rule of thumb for this I am quite satisfied it "should" be alright.
    3. Blank off the pipe to the intake swan-neck I used a bolt at the front of the engine but equally a small piece of hose attached at the rear with a blanking plug will do as nicely and probably look more OEM as it will be hidden under the engine cover.
    4. I used cable ties to secure the pipe and prevent it rubbing and chaffing. At the end of the newly install a small filter to prevent anything walking up the pipe! I paid £3.65 off ebay! it looks the part is just visible in the last pic and is perfect for the job.
    5. Clean the EGR out and the intake as it really is amazing how the oil vapour combines with the soot to clog everything it touches.
    6. Time to stick the kettle on! have a brew and a Biccie once you have cleaned your hands that is!
    Now the other pictures are in the following post
    http://www.vectra-c.com/forum/showthread.php?t=110142
    kings lynn, norfolk
    Exellent write up derek and no probs use as many as my pics as you want
    Also if any one else wants any advice then derek or I can help just ask if more pics are needed I will happily take some more to show ppl this is a definate must of a cheap mod to help increae mpg and power and also to keep the engine working better for longer
    Lancashire
    Trim : XP1
    Mileage : 66000
    Does it drive any different...?
  1. For Sale: Galaxy S3 Box,charger,Ear phones,Battery Team gb case,leather flip case
    By bigmac in forum General items for sale
    Last Post: 30th December 2012, 22:03
  2. Crank case breather pipe?
    By Leemarksmith in forum Engine & Drivetrain
    Last Post: 27th May 2012, 22:00
  3. front crank case oil seal
    By b3kaw in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2010, 22:50
  4. crank pulley
    By andyc#elite in forum General Chat
    Last Post: 18th November 2007, 09:12
