Results 1 to 10 of 27
Thread: Piston rewind tool
    Jul 2010
    lancs
    Default Piston rewind tool
    Hi,
    Just recently bought a Vectra C 2.2 SRI (2003). The rear pads have worn down and I tried to replace them at the weekend. However i couldn't get the pistons back in with pliers. I was looking to buy a rewind tool but they are around £40. Anyone managed to get a similar tool that worked that is cheap?
    Richard
    Regular Member leonvectrac's Avatar
    south shields
    some buy the one in halfords made by laser and modify the pins to fit
    Regular Member crespo's Avatar
    Bournemouth
    I just wedge a hammer in there and push the piston back with that.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Quote Originally Posted by crespo View Post
    Please don't do that. You will ruin the thread.
    Open the master cylinder then use the pliers. It will work just keep going.
    Regular Member stuartbat's Avatar
    May 2008
    shropshire
    but you are supposed to twist the piston as you push so you dont damage the seals
    Regular Member mitch's Avatar
    WIGSTON, LEICESTER, LE18
    when i did mine i used long nose pliers and found out you turn clockwise plus you need a lot of pressure to get it to return inside.
    Sigtuna Sweden
    It should look somthing like this:
    Uploaded with ImageShack.us
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    That looks a bit like the one i got
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by 164161413 View Post
    I had one just like that, lent it to my brother in law months ago for his 4x4. He never used it now says he'll return it "when he decides I really need it" not when I say I do. He's moved so can't go bash on his door
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Quote Originally Posted by stuartbat View Post
    No your supposed to wind the Rear Pistons back because if you dont they wont go in, the pistons are threaded. The Fronts are push back, think maybe Crespo didnt notice he said Rear Pads. My last car had wind back rear calipers too, wonder why they use wind back on the rear but push back on the front.
  1. Brake piston/rewind tool
    By 123rado in forum Suspension, Wheels & Brakes
    Last Post: 26th December 2012, 12:04
  2. piston rewind tool size
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2012, 11:43
  3. piston rewind tool
    By brtsam1 in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2012, 20:39
  4. Piston Rewind Tool
    By Jamesx81x in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2012, 13:07
  5. Piston Rewind tool
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2010, 10:58
