Thread: injectors need to be coded?
    aberdeenshire
    Default injectors need to be coded?
    Hi folks, my no.2 injector has failed on my 1.9cdti so i'm looking to replace it myself. Do these need recoded or can i just swap it out?
    Many thanks
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    They need to be coded to the engine ecu mate,
    Regular Member DaveW555's Avatar
    Cannock
    Normally I would agree plasma but there's a little niggle in the back of my head that says they dont need to be coded. I used to work at mercedes who use a bosch injection system (same as vx) for theyre common rails and the injectors on those are supposed to be coded but I could fit an injector from one car into another and it would run perfect so I'm not sure if the ecu automatically codes the injectors or if they all run a standard code.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I know the 2.0 Dti injectors are not coded so can't see why the CDTI ones are
    Irmscher Insignia CDTI 130
    Oct 2007
    estonia
    you can replace the injector and not program it - engine will work. Although if you want to be sure that all cylinders are working in balance I suggest you have the replaced injector programmed.
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    They will work without being programmed BUT wont be in perfect balance until the ECU has been programmed with the new 'flow rate' which varies from injector to injector
    Quote Originally Posted by bigmac View Post
    That is because they are 'dumb' injectors... They just pass whats been given to them they dont do any switching, its the fuel pump which does the hard graft of switching the fuel whereas with the cdti the injector is a 2 stage electronic device which actually controls the amount of fuel to inject...
  1. injectors
    By sandy13 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th January 2012, 13:12
  2. injectors
    By damo-SRI-T in forum Petrol Engine related
    Last Post: 9th June 2011, 08:02
  3. Injectors
    By andymagee1982 in forum Engine & Drivetrain
    Last Post: 8th November 2008, 20:24
  4. new injectors
    By Gr4eme in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2007, 21:52
vivaro 1.9 injector coding
vivaro injector coding
vectra cdti injector coding
are vivaro injectors coded
does the astra 1.9 cdti 2008 need injector reprogram
vivaro 2.0 injector programming
1.9 cdti injector coding
programming vectra c injectors
vivaro injector programming
https:www.vectra-c.comforumshowthread.php114844-injectors-need-to-be-coded
opel coding injectors
do i need to reprogram injector
program injectors zafira 1.7
zafira 1.9 cdti programming injectors
vauxhall cdti need injector programming
how to code injectors corsa
vauxhall signum 1.9 replace injector
how much to have vivaro injectors codes
vauxhall corsa 1.3 cdti injector coding
does a 2005 astra 1900 cdti need new injectors coded in
can i fit my astra ecu to a zafira 1.9
zafira 1.9 cdti injector need coding
opel corsa c 2005 1.7 cdti injector programming errors
Vivaro injectors program
Corsa c Petrol fuel injector recoding
