Thread: Car with spanner
    Regular Member brotherkennyh's Avatar
    Swadlincote
    Default Car with spanner
    I keep getting a car with spanner light come on while driving, which I believe is related to the engine/transmission electronics.
    The light usually comes on in 3rd/4th gear between 2000-3000 revs. Once it comes on the power is very much reduced.
    I have a 2.0L DTI.
    Anyone know what this is or might be?
    Kenny
    Regular Member 74-lad's Avatar
    no where at the moment
    you need to get the fault codes first
    Swadlincote
    I will give it a try later today and report back.
    Full Member Big Sig's Avatar
    I'd guess at a split boost pipe or a dirty boost sensor, maybe both ad they are both common faults on dti's.
    Swadlincote
    I tried the method on here to get the fault codes and it didn't work. I just ended up having trouble starting the car afterwards.
    The car with spanner light flashed when I turned the ignition back on and wouldn't start.
    I left it a couple of minutes and it started fine, but I still haven't got the fault codes.
    Any thoughts or do I need to take it to the garage to be read?
  1. Help - Spanner, then no spanner!
    By Ricksh in forum Engine & Drivetrain
    Last Post: 1st October 2012, 12:04
  2. Spanner
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2010, 20:09
  3. car with spanner going through it?
    By monty2000 in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2010, 13:00
  4. My spanner is always on.....??
    By smiley-sri in forum Engine & Drivetrain
    Last Post: 1st October 2009, 18:54
  5. Oil can with spanner
    By Darryl2.2DTI in forum Electrical & ICE (including SatNav)
    Last Post: 21st May 2009, 01:14
