Thread: SRI 150 CDTI engine stutter
    Mar 2007
    Gloucestershire
    Default SRI 150 CDTI engine stutter
    Hi, my Vec seems to have developed some sort of fault - basically you can be driving along (with engine cold or hot) then all of a sudden there is an intermittent power loss for a split second, as if its being starved of fuel. This is becoming more frequent, but no lights light up when it happens, and even once I had cruise control on it didnt cut that out. Any ideas??
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    My car is doing that occasionally but mines is always occasional ie can be days of being fine then the odd hiccup. From what you are describing - yous is getting steadily worse then I would say you have the 3rd injector loom issue. To check if this has been changed then take the engine cover off, the injector plug third from the airbox should have blue clips and not the yellow one.
    I had the injector issue too, the car would stutter violently then after a week of this it would start to shut down.
    I don't know what is causing the misfire just now but I suspect a fuel filter but it is the garage getting looked at.
    Gazza4
    Mar 2007
    Gloucestershire
    Cheers Gazza - from doing a search on the injector problem this sounds like it could be my problem, as I also get the engine diagnostic light on from start up until it gets warm.
    I will buy the kit and give it a go, especially for £12!!
    Thanks again
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by sri150 View Post
    Thanks again
    No probs, the garage couldn't find anything - wasn't at a dealer though.
    Gazza4
  1. Engine stutter at 70mph.
    By Dobs in forum Engine & Drivetrain
    Last Post: 3rd December 2011, 09:56
  2. DTI Engine Stutter
    By keithtinman in forum Engine & Drivetrain
    Last Post: 29th July 2011, 17:11
  3. engine stutter
    By paul wingnut in forum Engine & Drivetrain
    Last Post: 16th December 2009, 21:07
  4. Slight engine stutter
    By frazejax in forum Engine & Drivetrain
    Last Post: 25th August 2008, 17:07
  5. 4,000 rpm engine stutter
    By djhepburn in forum Engine & Drivetrain
    Last Post: 28th February 2008, 21:48
