Results 1 to 10 of 19
Thread: speedo dials droping
    Regular Member rorycarz's Avatar
    Dec 2005
    AYRSHIRE SCOTLAND
    Default speedo dials droping
    at the begining of the year i put th car into the dealers to activate the heated rear seats as my car had been wired for them (i added the heater pads) .whilist talking to the young technition working on my car ,i told him that the traction control had stayed on one day & that it was a one off ,he said that the vectra cs were prone to a bad connection at the abs, so he greased the connection (i thought this would make it water tight ) .........over the last few mounths i have had a problem where you are driving along & suddenly the needles on the speedo drop & all dash clock lights come on, the car runs fine & centre display still works ,then they will jump back on ........ this problem was a now & again thing that started to happen more & more . i looked this part of the sight to see if anyone else had the same problem . armed with a couple of posibile answers i took it to vaux today & they told me that it was my abs plug ( front of the battery ) that was at fault someone had covered it in grease & it was in fact the cause of the bad connection . i then told him it had been greased in there workshop ,he said that VX HQ has instructed workers no longer to use grease connections
    makes me wonder why he just didn't use a silicone spray to displace any water that may get into the plug...
    bet ya were worried that it was the 03 dash problem rearing it's head in your car...
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    Quote Originally Posted by rorycarz
    is that dunure castle in the background of your avatar mate?
    Dec 2005
    AYRSHIRE SCOTLAND
    ye i first thought it was a bad earth so i cleaned them all up no joy i even unpluged the abs & re-connected at one point still the same
    Dec 2005
    AYRSHIRE SCOTLAND
    yes it is dunure castle are you close
    Feb 2006
    Vehicle : Audi
    Trim : A5
    no mate i stay in east kilbride but i was down there 2 weeks ago for a wee day by the sea and must admit its a cracking wee spot weather was roasting and the place would be good for a meet IMO
    Jul 2006
    Mexico
    Thereīs a hole thread about this problem, I also have it....is a pain in the neck...could not find so far any answer to this....The plugs that you mention solved the glitch?
    Dec 2005
    AYRSHIRE SCOTLAND
    what do you know it s happening again .i took it back to vaux they say if it continues the abs (behind battery)(not in front as i stated earlier) plug on the harness will need replacing Ģ164 (aparently older vec cs have badly fitting abs plug treminals which has been amended in newer vecs)
    Northamptonshire
    Hi guys
    does this happen when its damp or when raining or if you just use the windscreen washers cos it seems like i have the same problem. It has cut out while driving a couple of times and then failed to start. It also has failed to start first thing in the morning.
    Jul 2006
    Mexico
    In my case happens when itīs dry (donīt have too much rain around here...I live in the middle of the friking desert)...and really havenīt found any situation that triggers the problem...for me...soo far itīs a computer glitch...just restart the car an goes back to normal.....but yeah now that you mentioned...I had struggled with the star/restart situation when this happens.
    I really would like to find what ever is causing this problem...but as far as I know nobody is really certain of what is causing it. Maybe the terminals that RORYCARZ mentioned would lead us to some answer.
  1. Speedo/Rev/Fuel Dials die then come back
    By mcally in forum Vectra C / Signum Troubleshooting
    Last Post: 15th November 2011, 18:06
  2. 3 Big Problems: Speedo Dials Die, Radio- no sound, Loss of Power
    By singlecore in forum Vectra C / Signum Troubleshooting
    Last Post: 18th December 2010, 20:23
  3. interchangable dials (speedo/rpm counter)
    By Caveman_nige in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 16:57
  4. no dials
    By delstevo67 in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2007, 17:56
