Thread: Cataclean.......... ?
    Leicester
    Default Cataclean.......... ?
    Last night talking to a taxi driver friend I happened to mention that my wifes 1.7 Puma keeps displaying the engine warning light and each time (4 times) the error code tells us that the emissions measured pre and post 'cat' are not showing sufficient change (drop).
    Has anyone used this stuff and does it work?
    Regular Member crespo's Avatar
    Bournemouth
    I find changing the worn lambda sensor usually does the trick.
    Regular Member PORKBALLS29's Avatar
    Epping
    i have tried it and it made no difference. You'll need to change the sensorrs mate.
    Regular Member signumturbo04's Avatar
    SCOTLAND
    i used it after changing both my lambda sensors and gave it a good boot up the road and it made a world of difference as it was failing the emmissions test for mot
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Quote Originally Posted by PORKBALLS29 View Post
    I used it on the wife's Fiesta a while ago, I think it is useful if you havent already damaged the sensor! But if you are putting it in once the lights come on, then I guess you have already damaged it!!!
  1. cataclean
    By wilson002 in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2012, 19:01
  2. Anyone used Cataclean??
    By Governor in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2011, 16:58
  3. Cataclean
    By Tam80 in forum The 'Off Topic' room
    Last Post: 3rd February 2011, 13:19
