Results 1 to 2 of 2
Thread: Dmf ?
    Regular Member Jim Bob's Avatar
    Widnes, Cheshire
    Default Dmf ?
    Hi,
    had my DMF replaced twice in the last month but now my car has developed a rattle when the clutch pedal is engaged - only when the clutch has had a lot of use tho, i.e. in traffic jams etc.
    Took it into Vauxhall last week and they said no fault found - even though I told them it needs to be hot!
    Could it be anything else? My warranty runs out March 2011, so would I get a further 12 months on the DMF from June 2010 when it was fitted?
    PRESTON
    not sure what the problem with the rattle is, but i can tell you that if a part is replaced under warrany it is only covered untill the end of the original warranty peroid. If you purchase and pay for one yourself, only then does it have 12 months parts and labour warranty cover, provided its from the stealers. In my experience, most motor factors will cover the part but not the labour.
