Thread: Key Fobb battery
    Regular Member Martii's Avatar
    wolverhampton
    confused Key Fobb battery
    Anyone know if its poss to change the key fobb battery yourself or is it a main dealer job
    Jul 2009
    The Rift, Cardiff
    DIY mate, stealers will rape you off. Just pop the case open and replace the CR2032. Not sure if its the same batt in the flip key tho.
    Regular Member mr.ian's Avatar
    Ayrshire
    Quote Originally Posted by ChrisBilly View Post
    Yes it's the same, flip key out and pull off the part below the vaux badge
    wolverhampton
    Thx guys
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    I think it says to then put the key in the lock to sync things.
    On mine ( 2007 model ) you need to put it in the ignition to stop the alarm - just done both my keys for pence
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. battery
    By Darren68 in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2012, 19:55
  3. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  4. Battery light on, 14.4V at the battery!
    By Saulty in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 23:29
  5. Battery.
    By jamesr in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2008, 23:18
