Thread: static discharge ( random )
    Shetland
    Default static discharge ( random )
    Good afternoon all,
    I have spend quite a lot of time in the seat of the last 3 weeks and have found a few things that are not right about my Signum 2006 facelift 2.8t. wondering if you lot could help-out if possible.
    If the audio is switched off ( cd70 navi ) driving for about 3 hour, I get a loud static sound via speakers ( bang ) like turning off an old hifi system and the speakers let of a slight bang ??
    The heater knob needs turning from cold to hot a few times to get hot air through ??
    left had main beam bulb keeps coming loose needs wiggle to fix ??
    any help greatly taken,
    cheers all
    Full Member Big Sig's Avatar
    I guess you have climate? DSo you get hot air problems with both sides of the car or just one? If you remove the panels in the footwell in the middle of the car then you should be able to see the air mix servos working when you alter the temp. Check to see they are moving ok.
    Shetland
    Hi Stig
    I have Air con, not climate design model. yep all vents are the same cold. I can turn the temp Dial from cold to hot a few times and then all good, ( flap sticking ??? )
    Could be a flap or a servo, take the panels off and check they are moving as they should.
  1. Vectra C battery discharge and OBC shows error in sensor.
    By jyot in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2012, 15:16
  2. Condenser regas/discharge Q? Wigan regasser req too.
    By voxvectra7 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th September 2011, 03:37
  3. Headlights - Gas Discharge or Not?
    By DanR in forum Electrical & ICE (including SatNav)
    Last Post: 7th April 2010, 21:15
  4. static electric
    By solorider in forum The 'Off Topic' room
    Last Post: 17th June 2009, 08:17
  5. GAS DISCHARGE Xeon lights
    By m3ath3ad in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2009, 23:18
