Results 1 to 10 of 17
Thread: spanner light help
    Regular Member vauxhall-john's Avatar
    fife, scotland
    Default spanner light help
    hey guys im after a wee bit help with my 2004 sri cdti 120
    after i fitted my turbo a few weeks back ive been having some troubles with my spanner/car light coming on and the car going into limp mode,
    basically when i hit any speeds between 65-85mph (on private roads..!) the spanner/car light comes on instantly and the car goes into limp mode and wont rev past 3500rpm, so what i do is stop the car switch off ignition and restart it, and the light goes out and the car drives perfect with no limp mode?? until i again get up to the said speed,
    can anybody shed any light on what could be the problem? as im kinda stumped on this one
    any help is appreciated
    cheers
    11 Post(s)
    Have you had the fault code(s) read out? Beats guessing what's wrong.
    The free pedal trick might work.
    fife, scotland
    the pedal trick doesnt work on my cdti, gonna get it on op-com or tech 2 and see whats happening but just trying to figure it out before it costs any more money
    fife, scotland
    anybody?
    Regular Member 74-lad's Avatar
    no where at the moment
    do you have black smoke? is the emissions control light on?
    fife, scotland
    had alot of black smoke when i first fitted the turbo but its calmed down now and the emissions lights not on, just the spanner light in the center of the clocks,
    have you checked all boost pipes for splits,connections and collapsing under load?
    Regular Member Marcosuk's Avatar
    Fife
    Where about in fife are u mate as i have a code reader u can borrow ..
    fife, scotland
    had a look at all the boost pipes but gonna check more in depth today,
    im in kennoway mate near leven, what code reader have you got? where in fife are you?
    Fife
    Ive got the http://www.auteltech.com/ms509.htm... If ur eml light is on then i should be able to tell wot it is & re-set it.. Im in burntisland mate..
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
