Results 1 to 3 of 3
Thread: Z19DTH cambelt setting warning
    Regular Member mozzer99's Avatar
    bristol
    Default Z19DTH cambelt setting warning
    A quick story:-
    Bought my 150bhp Vectra at auction and found it had no power. most of the reason for that was a blocked DPF - see another thread.
    Whilst waiting for air con parts (another story) I thought I would service it.
    It has a full service history but no mention of ca mbelt change. Rang the Vauxhall dealer who did all the services. Replied they had never been requested to change the belt. It appears that the belt was changed but by a cheaper garage:-
    Took it apart and found that there were red paint marks on the crank pulley and the camshaft.
    As there are no timing marks on the casing for the camshaft this is a by 'eye' method of retaining the current setting. As a whole tooth out is quite a noticeable and big mistake I was tempted to use the paint dabs again as the kit of special tools is £46. But bit the bullet and ordered the kit. Came to fit it today and found that the previous belt was one or maybe even two teeth out as can be seen by the gap in the arrows - the hole should go over the arrowed stud.
    Spring loaded camshaft locking pin wound into the hole
    It's quite a strain to get the cam belt right as it has to be very tight between the cam and crank. Without the locking tools I can imagine I would be a tooth out as well.
    So the moral is use the locking tools!
    I will add to this post if the power goes up!
    Top find
    Apr 2017
    Melbourne, Australia
    Vehicle : 9-3
    Trim : Linear
    Engine : 1.9
    Default I'm intrigued
    Did you ever notice a difference by changing the timing a couple of teeth. I'm going to do the same because I lost the timing, just need to buy the kit.
  1. z19dth broken cambelt
    By RyanNI in forum Engine & Drivetrain
    Last Post: 11th April 2012, 19:45
  2. z19dth fuel filter housing torque setting?
    By justin32 in forum Engine & Drivetrain
    Last Post: 27th December 2011, 11:31
  3. Z19dth cambelt change!!
    By signum_rob in forum Engine & Drivetrain
    Last Post: 12th November 2011, 20:57
  4. Setting cambelt tensioner 1.9cdti 150
    By Vectra Meldrew in forum Engine & Drivetrain
    Last Post: 28th August 2010, 13:31
  5. Cambelt setting tools
    By Python in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2008, 22:47
timing marks vectra 1.9cdti 150
1.9 cdti crank locking tool
crankshaft timing tool z19dth
z19dth cam tool
z19dth camshaft
z19dth camshaft locking tool
changing cambelt z19dth
