Results 1 to 10 of 14
Thread: sticking egr?
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default sticking egr?
    reading some posts about egr valves how do you know if its sticking? is there away of unsticking them ie putting a drop of oil on it?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Usually if its sticking then the power drop can be intermittent, and the power may cut in harshly. You could also get some uneven running at low rpm as it could stick part open.
    You can unstick them by removing them, separating it and cleaning/lubricating.
    Oct 2009
    Sandwell
    you know the plungers thing on then how easy is that ment to move last time i cleaned mine it was hard to move. I get that now and again were power will just be there and sometimes its **** like theres no boost
    Lancashire
    Trim : XP NAV
    The plunger in the solenoid side should move as free as a bird, the other side is a tad firmer, but shouldn't have any resistance.
    Oct 2009
    Sandwell
    mine must be faulty. when i tried to move mive by hand it was kinda stiff and hard to move. Gonna give it another clean on my day off from work what kind lube should be used on it? should you able to move the plunger by hand: i couldnt before had to use somat hard with force
    Lancashire
    Trim : XP NAV
    Yeah definately, should be very easy to move, no force at all is needed.
    Just drown it in carb cleaner and WD40 - you probably need to separate the solenoid completely, its probably corroded inside.
    Regular Member mr.ian's Avatar
    Ayrshire
    I have a 1.9cdti sri150 57 reg with absolutely no poke below 2000 revs, could it be the same problem/solution?
    Oct 2009
    Sandwell
    how much is a new egr valve for a dti?
    And can a new one just be pluged in and away you go or does it have to be programmed to the car?
    Regular Member eaglepva's Avatar
    Up North
    a new EGR valve for a dti is around £215ish i think.
    Lancashire
    Trim : XP NAV
    Quote Originally Posted by mr.ian View Post
    Being a 57 plate its more than likely mate.
  1. sticking
    By HARRY SRI in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2012, 22:23
  2. Bonnet sticking
    By booker413 in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2010, 18:59
  3. Acceleration sticking...
    By arkhan78 in forum Engine & Drivetrain
    Last Post: 19th February 2010, 14:19
  4. Sticking Auto Box
    By Gersh in forum Engine & Drivetrain
    Last Post: 26th December 2008, 10:47
  5. SHAN sticking to the LAW
    By shan in forum Quick Photo Album
    Last Post: 12th May 2007, 19:55
