Results 1 to 10 of 29
Thread: Had enough of bearing the noise!
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Vehicle : Vectra Hatchback
    Engine : 2.2 DTi
    Default Had enough of bearing the noise!
    I need a new front wheel bearing, on the near side. I believe that they come as a complete unit in the hub. Can I just check that this is the right part before I buy...
    Linky
    My car is a 2003 (53) SRi 2.2 DTi.
    Thanks in advance!
    May 2006
    Wiltshire
    Engine : 2.2 DTi
    Bump
    Apr 2008
    murton seaham
    be careful with aftermarket bearings as i got one fitted wich put my abs light on when fitted so i thought it was faulty went and got another one and exactly the same happend when i plugged it in so went and got a genuine one and as soon as i pluged it in the abs light went off so my advice would be buy a genuine one mate it will save hassle in future oh i saw another post on here with a guy with same problem
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    I've got an aftermarket bearing on mine & its been ok - no issues with abs lights etc. Mines an '02 2.2 dti, be careful cos the garage i used reckon there are 3 different types of bearing for that model vectra. They showed me the old bearing & it does looks a lot like that one on ebay but its hard to say for definate & I don't want to say buy it in case it doesn't fit your car.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    There are two different types of bearing on the Vec-C, IDS and non IDS.
    Aftermarket bearings are fine but don't go for the cheapest of cheap because as mentioned they can cause problems with the ABS/TC system
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    what is IDS?
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    I got exactly the same one m8 for the nearside, since it was fitted the car felt like the abs was kicking in way too early and didnt feel too good to drive, got no abs light though.
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Quote Originally Posted by keith1983 View Post
    what is IDS?
    Like keith asked... "What is IDS???"
    Cheers..
    Aug 2010
    Halstead
    Anybody able to tell me how to change a front wheel bearing?
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    yes i have done it.
    take bottom shock bolts off, track rod off knuckle, brake disc and caliper off, disconnect the wear pad sensor and abs sensor from the plugs that are situated on the shocker. take off drive shaft nut (you'll need a deep 32mm socket) Use special tool to push drive shaft through the hub. take out bottom ball joint bolt and the knuckle will lift off.
    Now you have to loosen the thee hub retaining bolts on the back of the knuckle and batter the old hub out with a big hammer.
    Note.. when fitting the new hub, note what position the abs sensor cable is at, if not the cable will not stretch to the plug.
    Hope this helps
  1. Vibration Noise - Wheel Bearing?
    By si_hoss in forum Suspension, Wheels & Brakes
    Last Post: 9th September 2011, 12:36
  2. Thrust bearing noise
    By robengland9 in forum Engine & Drivetrain
    Last Post: 21st February 2011, 13:48
  3. Wheel Bearing Noise Or Not? Help!!!
    By whatthevecisup in forum Suspension, Wheels & Brakes
    Last Post: 5th August 2008, 16:16
  4. Wheel Bearing Noise ?
    By STEVE S in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2008, 20:09
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
