Thread: outside tempreture stopped working on the car
    Regular Member kamar's Avatar
    bradford
    Default outside tempreture stopped working on the car
    Hi guys i just noticed that the outside temp has stopped showing the temp it just says F there now any advice plz if it can get working and how...mines also got sat nav if that makes any diffrence
    cheers...
    PRESTON
    it will be the outside air temp sensor, its behind the lower front grille on the bumper. cheap enough to be got from the stealers.
    bradford
    well if thats so i recon the garage havent put it back on as i had the front bumper painted & they had bumper off i think i better head back to them. cheers
    PRESTON
    if its got fogs check them, maybe they forgot to hook them back up too.
    11 Post(s)
    Quote Originally Posted by barney490 View Post
    The bulb failure light should come on if that were the case.
    Full Member Big Sig's Avatar
    I wouldn't bother going back when it's probably a 2 min job to check if it's plugged in.
    bradford
    fogs work fine... where do i look iyl sort it if it was easy enough...
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Pop the bonnet, and look straight down between the bumper and the radiator. Just behind the bumper right in the middle you should see some wires. Temp sender unit it just there.
    11 Post(s)
    OP's car is a facelift Vectra (reg 06) so that won't be possible.
  1. Sub has stopped working
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2012, 16:35
  2. Sat Nav Stopped Working
    By alhambra in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2012, 19:24
  3. DAB stopped working
    By sandman1001 in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2011, 22:27
  4. Fan stopped working
    By andyxedos in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2009, 23:18
  5. Air Con stopped working
    By pvmoore in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2009, 22:31
