Thread: power tailgate & fuses
    blackwood
    Default power tailgate & fuses
    Ok. i no these are daft questions to those of you who have had veccy's for a long time, but here we go.
    1. is the tailgate supposed to power both up and down
    2. or just unlock on the button and be manually raised, then power all the way down on the button.
    the reason i ask this is mine, is option 2. and reading the owners handbook i can't work out which is right.
    secondly the fuse box's in the handbook it states 3. my estate only has 2, and the fuse's don't match what the handbook states, is there a haynes manual that show's the electrics better?
    any help welcome
    PRESTON
    on vehicles fitted with power tailgates, the tailgate should power up and down. press and RELEASE button three, the tailgate should unlock and power open, then press and HOLD button three till the tailgate has powered closed and locked, then release button three. it's essential that you keep holding button three till the tailgate closes fully and locks. also, once open, there should be a manual switch on the right hand side of the tailgate,near the latch, that you can press once and it should power down and close.
    i thought there were three fuse boxes, one under the bonnet, one right hand side of dash (can be seen with drivers door open) and one in the rear quarter.
    blackwood
    thanks barney.
    thats what i thought, it has been in the workshop for the last three day's being worked on still no joy, comes down ok, but will not go up under it's own steam.
    they have changed the motor & cable, and both struts also checked the alignment of the tailgate in the bodyshop.
    booked in again next friday, but they can't seem to solve the problem.
    thankfully its being done under warranty
    PRESTON
    lucky warranty is covering it, those motors aint cheap. Sounds like a remote signalling error to me, i bet they will change the body control module next. Let me know the outcome, so i can add it to my little book of Vectra ailments , lmao..
  1. Air-Con packed in! No power to compressor, fuses ok.
    By Taffyopel in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2011, 17:28
  2. Retrofit power tailgate
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2010, 20:18
  3. Power Tailgate problems
    By purple170503 in forum Vectra C / Signum Car Chat
    Last Post: 15th September 2009, 22:51
  4. Lubrication of Power Tailgate
    By Hirobofly in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2009, 21:51
  5. Power tailgate retro fit
    By Legless in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2007, 19:30
