Results 1 to 10 of 24
Thread: strange light on dashboard
    Jul 2010
    kent
    Default strange light on dashboard
    Attachment 33671
    hi there was wondering if anyone could help me out. This icon has appeared on the dashboard of my vectra i have checked the manual and it says that this symbol means that a bulb has gone but only if this symbol is red mines not red its yellow so am very confused and was wondering if anyone could help.
    thanks
    andy
    Dunstable
    No, it's only yellow as far as I'm aware. Wouldn't make sense being red or yellow as the bulb is either working or not. Check your bulbs, you'll find one has blown
    Jul 2010
    kent
    thats what i thought the bulb would either work or not but i have checked every lightbulb on the car and they are all on and working fine
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    One is about to blow then. Keep an eye out. If you have the info centre in the car it should let you know what bulb it is.
    Regular Member G4GAV's Avatar
    Bristol
    mine is doing that latey, all my blubs work and the light is on, and it say on the center dispaly too that the brake light is out.... might be the center brake light up the creek !
    On another planet
    Engine : 2.0
    Yes, as the lamps get older (with use) the filament burns away to such an extent that the resitance becomes higher and thus the car thinks that it has failed. The lamp still works, but will burn out completely soon.
    Jul 2010
    kent
    cool cheers guys i will keep an eye on it the centre screen hasnt flashed anything up
    Quote Originally Posted by G4GAV View Post
    If a brake light fails then another bulb takes over.
    i.e. the upper of the two tail lights is also the brake light, but if this bulb fails then the lower of the two tail lights takes over the role of tail & brake light.
    So first impressions when you look at the back of the car to check the lights shows you've still got two working brake lights, but upon closer inspection you'll see that one of them is lower than the other one.
    Regular Member Martii's Avatar
    wolverhampton
    I had this light come on last weekend andy .. checked all the bulbs and everyone was fine .. so i thought its gotta be a bad connection so i removed every bulb and replaced them making sure thay where pushed all the home .. and hey presto the dash light had gone
    Jul 2010
    kent
    cool i will remove them all and check they are all in tight
  1. light on my dashboard
    By Kenny_Exclusiv in forum Engine & Drivetrain
    Last Post: 4th March 2011, 09:36
  2. light on the dashboard?????
    By kayli in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2010, 10:19
  3. emmissions light on dashboard
    By pmitchell in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2010, 17:57
  4. insp light on dashboard
    By studmuffin in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 00:16
  5. Can anyone get rid of steering light on dashboard???
    By LancsVectra in forum Vectra C / Signum Troubleshooting
    Last Post: 1st August 2008, 13:41
