Thread: aircon fan CRAZY
    Milton Keynes
    confused aircon fan CRAZY
    Anyone have a clue what could happen to my baby?
    I went to automatic car wash ( my mistake ).
    I have had engine running and aircon on wile my car became clean again.
    Straight after I switched off aircon and drove home ( less than mile)
    20 minutes later fan decided to blow as much air as it can.
    It is now blowing only hot air regardless of the aircon settings, what is worse it blows it even when turn off the engine.
    I have pulled fuse to rescue battery.
    ANY ONE HAVE AN IDEA WHAT HAPPENED
    Doest it sounds like ECU?
    If so, what can be the cost of repair?
    Thanks in advance for all serious answers
    Radek
    Full Member Big Sig's Avatar
    Is the pollen filter drain blocked and a load of water has gone into the fan electrics? Is the passenger footwell wet?
    (or have you switched the CC to "lo"?)
    Milton Keynes
    no idea. how can I check it?
    Lift the mat and use your hand.
    The pollen filter, lift the bonnet, take the rubber strip off at the bulkhead, you will see a letterbox size flap on the passenger side. Lift it and the filter is under there. You will see the drains under there too.
    Use the search button as I am sure there are pics of this too.
  1. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  2. crazy led
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 20th November 2011, 21:14
  3. Crazy people, crazy drivers.
    By Grumpy1954 in forum General Chat
    Last Post: 8th October 2010, 19:42
  4. go crazy!
    By AKeeNShoT in forum Photoshop section
    Last Post: 19th April 2010, 09:58
  5. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
