Thread: air con working but not getting cold?
    Regular Member wilbur1's Avatar
    wrexham
    Default air con working but not getting cold?
    Hi,
    i need some advice i got a vectra 1.9cdti sri (150) 56 plate when i put the air con on the pump kicks in but it doesnt get cold my mate put a gauge on and says its fully charged with gas is there another way of checking the gas incase his gauge is faulty or is it another problem? any help would be appreciated.
    Apr 2008
    High Wycombe
    Vehicle : Vauxhall Insignia
    Trim : SRI NAV
    Engine : 2.0 CDTI 140
    Mileage : 20000
    I'd take it to a garage with an air-con machine and get them to check. The place near me does a free check, if your lucky it'll be a simply case of a re-gas, normally about £50.
    If its more than a re-gas they should be able to tell you.
    Regular Member Jekyll & Hyde's Avatar
    Walderslade Woods,Kent.
    Got mine re-gased at vauxhall as it wasn't cold enough, turned out it didn't need re-gasing, just a new pollen filter, the air flow now is 100% better.
    Don't forget to hover all the leaves & muck out before you remove the old filter as you don't want it droping down the pipe work, & again when the filter out.
    Vauxhalls wanted £32 supply & fit , just to supply was £9.60, & you guess what i chose to do (it took five minutes).
    Tho' on another note climite control is crap, much prefer the air con as on my pride & joy (1997 Ford Probe V6 GT), ice cold & it just keeps getting colder
    Hope it helps
    wrexham
    Thanks.
    i'll take it for a re gas and see what they say and i'll change the pollen filter
    Will let u no. cheers
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    yes mate gas levels get low but also stale when its old
    Regular Member Happy Dave's Avatar
    Nr Blackpool
    could a pollen filter effect the temperature? Had a new condenser in 3 weeks ago and whist its cold its not as cold as I think it should be
    11 Post(s)
    Why not try taking out the pollen filter. Only a 2 min job.
    May 2008
    scotland
    Hi! You can buy a refrigerant 134A for re-gas on e-bay and it's much cheaper than going to a garage, but have it check first coz it might not be the refrigerant, might be the expansion valve or a leak on your AC system.
    11 Post(s)
    Quote Originally Posted by berky View Post
    Not one of those poxy DIY cans surely?
    Waste of time, IMHO, and only a few pennies cheaper than someone like KwikFit. And the can won't tell you that you have a leak but you'll still have to buy the can, whereas KwikFit won't charge you a penny if their machine finds a leak.
    That aside, isn't it sometime soon where the law changes with regard to AC gas and who can sell / buy it?
  1. random cold knock/tick sound when cold - 1.9 cdti
    Last Post: 18th January 2013, 18:59
  2. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  3. radio working, not working, working again
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 00:59
  4. Replies: 0
    Last Post: 10th November 2011, 22:58
  5. wipers not working when cold
    By johnnyg in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2008, 21:45
