Thread: Front Brake Part Number ?
    Regular Member Grahamy's Avatar
    Ryton
    Default Front Brake Part Number ?
    As in title , does anyone have a upto date part number for front brake pads, 285mm for a 1.9 cdti
    Ive had a look in the part number section at these numbers
    Brake pads
    285mm fronts - 93183728
    314mm fronts - 93176379
    278mm and 292mm rears - 93183140
    here is the reply from a dealer after an enquiry..
    unless yours is a police vehicle these are not for your vehicle ,
    you need part number 93188112 which are £78.73 inc vat plus 6.45 p&p
    thanks
    So is 93188112 the correct part number for the front pads
    any help with this will be more than welcome
    to be honest your better off ringing lmf vauxhall and talking to them , theyll know exactly what you need and will probably be cheaper
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    You'll be better off buying the disc and pad kits as they normally work out cheaper in the long run.
    Regular Member Bullylad's Avatar
    Bolton
    Mine is a 1.9 cdti 150 and I recently used a company called 'Blackburn brakes' who sell almost every consumable car part you can think of.
    I bought replacement pads for the front and rear, total cost £55. These are manufactured to the same standard as VX parts. I have had them on the car for 7months now and 7k miles without any issues.
    I just gave them my reg no and they identified the correct part.
    Just dug the receipt out and they can be contacted on 01254 53900
    Good luck!
    Regular Member WHOOSH05's Avatar
    On the back wheel
    Just got discs and pads for my cdti from bristol street for £62 trade gis a shout if you need anything
    Ryton
    cheers for the info,
    but i went for the mintex brake box off ebay
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
  1. brake part number request
    By dave16v in forum Handling & Braking
    Last Post: 22nd February 2008, 21:33
