Thread: Front end noise
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Default Front end noise
    Over the last week or so I've been hearing a metallic squeal from the front end. Mainly at low speed and dramatically louder in a right turn.
    I've had both fronts off and checked everything for witness marks, damage, bends, scrapes, looseness, fouling, wear, muck, fluff, dust & custard, all to no avail.
    It's still there when rolling with clutch in. There's no pull to either side when braking. The discs run true, the pads have masses left.
    I've narrowed my thoughts down to possibly a dragging/seizing brake and a couple of bods at work seem to be leaning that way as well.
    However, before I start taking things apart further if I don't need to, does anyone have a definitive answer or even constructive thoughts ?
    It's a standard 3.2 V6 GSi Hatchback. Standard springs and brakes.
    (OK, so I know all of you have your ideas.... I'm just being polite by asking )
    PRESTON
    wheel bearing maybe?? allowing the disc to move slightly out of true and just touch the carrier? We had a van at work doing this and it had new discs and pads which cured it, even though there was plenty left on the old pads.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Brake disc heat shield mate, it will only do it when the discs heat up and expand
    Just bend it back a bit off of the disc
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Well I have an answer on this one. Personally I thought I'd eliminated it as a possibility, but it turns out I was wrong:
    Actual cause : Stones trapped behind a tiny guard just below the lowest suspension link on the nearside hub. It's one step away from impossible to see and given this guard isn't the usual flat plate, it doesn't feel out of place either. However, 2 small stones fell out when I bent it away from the disc and the noise has been absent ever since.
    One hell of a noise for something so simple !
    But it's sorted now
    Regular Member Martii's Avatar
    wolverhampton
    Hi andy iv'e just had my motor back from the garage took it in for a simlar sound , i got mine while going over the ****** speed ramp in my area or when ever i pulled up sharpish, could allso get it to sound by reversing then brake and then pulling off .. any how it turns out the garage had put cheapo pads in....... its got vx pads in now and all seems fine noise gone..
    so pads it was for my noise
  1. Noise From Front
    By spennny in forum Suspension, Wheels & Brakes
    Last Post: 6th October 2012, 14:06
  2. Replies: 3
    Last Post: 8th September 2012, 12:13
  3. noise from front end
    By micks edition 100 in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2011, 20:34
  4. OS/Front noise
    By clightowler in forum Suspension, Wheels & Brakes
    Last Post: 1st February 2010, 19:00
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
