Results 1 to 2 of 2
Thread: Limited Revs
    Jul 2010
    Caerphilly
    Default Limited Revs
    Hi Guys,
    I have a problem when starting my 1.9CDTI150, the Revs seem to be limited to 2K - does this mean the car is in limp mode? every now and again it seems to clear itself and I can drive normally but I understood that once you dropped into limp mode you would remain in limp mode until someone had cleared it from the ECU.
    Regular Member LADmachining's Avatar
    Hampshire
    Depending on the nature of the problem, the ECU will come out of limp mode when the fault clears, or it will remain until the engine is stopped and restarted.
    If the fault is detected as soon as the engine starts, the car will remain in limp mode until the fault is rectified.
    Codes can remain in the memory of the ECU, but as long as the fault is not present, the car should drive normally.
  1. Pay pal account limited help
    By rob warrington in forum General Chat
    Last Post: 29th June 2012, 23:33
  2. Intermitant Problems Starting - Revs limited to 2K
    By Beridor in forum Engine & Drivetrain
    Last Post: 6th July 2010, 16:30
  3. Limited revs and power down
    By Ste in forum Engine & Drivetrain
    Last Post: 24th November 2009, 11:59
  4. Bah my vans limited to 70 mph !
    By deanos in forum General Chat
    Last Post: 2nd June 2008, 14:20
