Thread: Park Pilot Vectra 2005 pre facelift
    Nov 2009
    surrey
    Default Park Pilot Vectra 2005 pre facelift
    Hi,
    I have an open circuit on park pilot switch.
    But I have no switch nr the radio.
    Did they have one when factory fitted?
    Trying to work out If it's been removed and a blank plate fitted instead.
    Justin
    Dunstable
    Yes there should be a switch there, Bottom left below the hazard warning light button. I have fitted one to my dash http://www.vectra-c.com/forum/attach...3&d=1269896982 I use it to turn my front sensors on/off as I fitted them myself using an aftermarket kit.
    Nov 2009
    surrey
    Mine was fitted from factory which is why I was wondering.
    I've seen them on many veccies and thought this was fitted to allow you to turn them off.
    Thanks for the reply.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    You can fit one but it will work without. The problem must be else where
    Nov 2009
    surrey
    Ah, thanks.
    I've checked Fuse F27 (has a piggy back fuse with 2x 5amp fuses) which seem all ok.
    I can read the Pilot ECU
    I get
    U2107 - Invalid Data from BCM (Body Control Module)
    (71) - Present
    B0952 - Loudspeaker Circuit Open or Low Voltage
    (06) - Present
    Should I next check all the connections and clean to be sure with electrical cleaner..
    I'm not great with electricals..
    Justin
  1. Park Pilot
    By BigWilko in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2012, 22:39
  2. Park pilot alert but I don't have Park Pilot
    By krisby in forum Vectra C / Signum Troubleshooting
    Last Post: 21st November 2011, 10:58
  3. Park pilot
    By hairy31 in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2010, 16:58
  4. Vectra Estate Rear Park Pilot Bumper Trim
    By tramman in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2009, 01:42
b0952 vectra c
b0952 opel
