Thread: Bleeding The Coolant...?
    Regular Member Jezzy's Avatar
    S.E
    Default Bleeding The Coolant...?
    Is this how you do it?
    1) Remove cap from coolant expansion tank
    2) Pour in coolant/water mix until it reaches the level mark
    3) With coolant tank cap still off, start the engine and run it for a while
    4) Get the engine hot enough for the thermostat to open (and if you have the 2.0T open the bleed valve on the coolant hose until water starts coming out)
    5) Turn engine off, top up coolant to bring it back to the correct level, refit cap
    Presumably there's no danger of coolant shooting out of the expansion tank whilst the cap is off?
    Oct 2007
    Shropshire
    I toolk the lower rad hose off to drain mine.
    Then I filled to the level on the header tank. Then I ran it up to temp with the cap on. As soon as you see the level drop in the expansion tank, turn it off. Let it cool for a while and remove the cap and top up to level again.
    Check the level after the next jorney nd top up if necessary.
    Thats what i did.
    S.E
    Quote Originally Posted by mucklestone View Post
    Thats what i did.
    Where does the air exit then, if the cap's on?
    through the cap , most exspansion tank caps have pressure relief valves built in to stop tthe system exploding if the pressure was to build up
    East Midlands
    Also remove the right hand hose in bulk head which goes to heater matrix,start to fill system at expansion tank...when you see coolant start to trickle from outlet,quickly replace pipe...this stops air locks in the heater matrix.
  1. Bleeding the coolant
    By iRocco in forum Engine & Drivetrain
    Last Post: 2nd February 2014, 18:11
  2. Bleeding Vec. 150 ?
    By mickyh7 in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2012, 20:03
  3. bleeding bleeding and adjustment
    By noudder72 in forum Suspension, Wheels & Brakes
    Last Post: 26th December 2011, 11:29
  4. Bleeding Brakes - Few Q's
    By yoclick in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2010, 17:10
  5. Diesel bleeding
    By craigbarlow18 in forum Engine & Drivetrain
    Last Post: 25th September 2009, 19:31
how to bleed coolant on vectra c www.vectra-c.com
vectra coolant bleed valve
