Thread: swapping bosch vp44 pump?
    northern ireland
    Default swapping bosch vp44 pump?
    Hi,
    Has anyone ever taken a bosch vp44 (psg16, twin socket) from a donor car and put it in their own? Do the two pumps need to be an exact match or can it be a similar pump and therefore change the main ecu from the donor car as well?
    I'm in a dilema and a local mechanic is 100% certain he can take a pump from another car and put it into mine even though they're arent an exact match! To do this he is also changing main ecu, etc.. and re-programming to tie in with my car.
    Any advice would be greatly appreciated. He is charging £250 for new pump + £150 for labour.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I am assuming that this is on a dti mate. You can move the Vp44 from one car to another but itr will require the old pump to be decoded from the other car using Tech 2.
    I have heard that it can also be done by using the old pass card from the doner card but I cannot confirm
    northern ireland
    yes its a dti. the guy said he would do exactly what you described, what's confusing is that i rang the vauxhall dealer and a diesel specialist who both said it could only be done if pumps were an exact match, i.e. 0470504204 number must be same.... in my case the numbers arent exactly the same which is why im worried!!
    just wanted to check to see if anyone else did this in the past before i go ahead..
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    hi i have done this changed a pump the numbers didnt match it was coded into my car useing the security code from donor car.
    llanelli
    i just changed the engine in my dti and the pump that came with the new engine i knew was coded and a different number to the 1 fitted on my orignal engine i just put my orignal pump on the new engine and all is fine.
    i did enquire about using the pump that came with the engine vx said
    they need sec code from donor car or vin and n-plate and the sec code ect from my car
    and about 75 pound lol
    easy option was just to change pump my self
  1. Bosch VP44 Diesel Pump 2.0 DTI
    By Madmarky01 in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2012, 18:16
  2. Bosch fuel pump vp44 2.2dti
    By davesignum1988 in forum Engine & Drivetrain
    Last Post: 12th September 2011, 13:41
  3. diagnosing faulty bosch vp44 pump
    By lenny32 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th August 2011, 22:56
  4. swapping bosch vp44 pump
    By lenny32 in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2010, 11:42
  5. Diagnostix VP44
    By SteveA in forum Diesel Engine related
    Last Post: 24th October 2005, 20:18
Bosch Vp44 Pump Control
