Thread: Full door replacement- Help please
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Default Full door replacement- Help please
    Hi all. I am helping to replace a friend's passenger front door tomorrow.
    1. Does anyone know how to detached this wire loom from the front passenger door?
    2. Will the new door wire loom work with the car or will I have to transfer the old loom into the new door for it to work?
    3. Also will the electric mirror and window work without transfering the old ones?
    Any head up, help or hints will be appreciated. Thanks.
    P.S. I have checked under the how 2's but it only covered the conversion of rear manual window to electric.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    1; lift upin the plug, you can see on the top on what to pull
    2: only need the DDM/PDM from old door (excepts if door is from facelift and yours is prefacelift)
    3: only need the DDM/PDM from old door (excepts if door is from facelift and yours is prefacelift)
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Thanks for that kenp. Will give it a go 2moro. any more contributions or heads up is welcomed.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Default Door lock sensor: Help please.
    I am assuming the door lock mechanism of a corsa is the same with that of a vectra.
    Complete n/s front and rear doors replacemnt was done on friend's corsa without removing anything from the old door into the new one. All electrics (mirror, window, central locks) work fine but when he tries to move the car around, a buzzing sound and an "open" light comes up on the dashboard.
    Is there any sensor on the door lock or door which is making the car not to recognise the new door fitted and thus making it to report door opened?
    Kenp mentioned to move DDM/PDM from old car, will this look like what's in the attachment for a corsa?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yep the sensor is built into the lock mechanism, the new one may be knackered, worth just swapping to old one accross
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Thanks a million. will give it a go.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    As an update, both the old lock mechanisms have now been swapped (50mins job) but unfortunately, the problem is still there. Grrrrrrrr.
    Battery has also been disconnected and reconnected again to see if it will reset itslef. NO. That did not work also.
    Engine : 2.2 Direct
    is there also a ddm on a corsa? as you might need to swap the wiring to then...
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Quote Originally Posted by kenp View Post
    Nope, no ddm/pdm on the corsa. I have stripped the old doors down. Nothing like that.
  1. PDR or a replacement door?
    By John LE in forum Bodywork & Interior
    Last Post: 5th February 2013, 01:08
  2. Door replacement
    By 1ctchris in forum Bodywork & Interior
    Last Post: 29th January 2011, 03:45
  3. Cost of a replacement door?
    By 1ctchris in forum Vectra C / Signum Troubleshooting
    Last Post: 29th January 2011, 03:36
  4. Signum Timing Chain and Full exhaust replacement?!!!! help
    By cjporter in forum Engine & Drivetrain
    Last Post: 12th November 2009, 19:40
  5. full set door handles
    By ks246 in forum Parts for sale
    Last Post: 25th May 2009, 10:15
